Headphones vs Monitor: HDMI audio, SRS for Monitors, & Realtek ???
Miranova23
3D Artist in Training
Pro User
10:53 PM
Philadelphia
I'm getting frustrated with trying to get all these options to play together correctly when it comes to my headphones. When I plug my headphones in the front jack, nothing changes unless I manually switch the default Playback Device. All things in question work, and well. However, depending on the convoluted configuration at the moment, either the monitor will keep playing & the headphones will play nothing, OR the monitor will keep playing & the headphones will also start playing.
Setup right now:
Monitor= ViewSonic VX2253 22"
(built in speakers, I own no others)
Connected to my video card via HDMI.
Connected to back green audio input.
Relevant internal settings through monitor= set to "HDMI PC" (as opposed to AV)
Audio input set to HDMI​
Onboard Audio= Realtek® ALC 892 8-Channel High Definition Audio CODEC
This is what the green audio plug is plugged into from the monitor.
Controls the front headphone jack.
I have tried as many different combinations of settings as I could think of. Any ideas how to make the monitor speakers play nice with the headphones???
d(--n--)b
Windows 7 Pro x64 SP1AMD Phenom II x6 1090T Black Edition 3.2GHzPatriot G ‘Sector 5’ Edition 8GB (2 x 4GB) 16...
ASUS M4A88TD-V EVO/USB3
Patriot G ‘Sector 5’ Edition 8GB (2 x 4GB) 1600MHz
(onboard) Realtek® ALC 892 8-Channel High Definition Audio
Transcend SSD720 2.5" SATAIII 64GB SSD; Western Digital Caviar Green WD20EARS 2TB 64MB 3.5" HDD
LG WH10LS30 10X Blu-ray Burner with LightScribe
CORSAIR TX Series 950W ATX12V 80 Plus Bronze
Cooler Master HAF X NVidia Edition; 5 Green LED Fans!
CORSAIR A70 120mm Dual-Fan
Verbatim 97472 Mini Wireless Slim
bundled Verbatim 97472 Wireless
Ultraportable/Desktop Replacement Laptop:
circa Oct 2006,
Dell XPS M1210,
Windows 7 Professional 32-bit,
Intel Core 2 Duo T7200 2.0GHz,
3.25 (4) GB of RAM,
NVidia GeForce Go 7400,
500GB Seagate Momentus 7200RPM HDD
Normally, when you have something connected to the HDMI port on the PC, the HDMI becomes the default audio playback device. Thus the regular PC audio (Realtek in your case) is not used. This would account for not having headphone audio. You can manually change the default playback device to "Speakers" (your PC sound device) and then you should get the headphone sound. I would suspect you will have to do this every time you boot your PC.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
When I set the default device to Realtek's "Speakers," the sound comes out of BOTH the headphones and the monitor. I even disabled the SRS for Monitors (literally the same jack as Realtek is looking at) & HDMI audio...
circa Oct 2006,
Dell XPS M1210,
3.25 (4) GB of RAM,
What I don't understand is, since audio is transferred through both the HDMI (which can be disabled/uninstalled), AND the green audio plug/jack, WHY won't the Realtek driver of said jack recognize that as regular speakers? Why does it make it a new device? Both "SRS for Monitors" AND "Realtek Speakers" playback out of the monitor as would be expected, the headphones play faithfully when plugged in, but why does it not then "mute this rear output device when headphones are plugged in?" (this is checked under "device advanced settings.")
Right now, if I want to listen to ONLY my headphones, as would be the point of them, I have to go into the monitor's onscreen menu, switch "Audio Input" from "Audio In" to "HDMI," AND switch the Default Playback Device to Realtek Speakers. And, I think, the audio from the jack and not the HDMI, sounds better. The sound quality of the monitor is generally crappy all around, so any little improvement is welcome. =/
I guess I should just buy a cheap set of speakers, and totally disable the monitor's sound abilities... =(
circa Oct 2006,
Dell XPS M1210,
3.25 (4) GB of RAM,
Enable the Front Panel Jack detection and see if that makes a difference. I don't have a Realtek system, but I've seen posts about how to configure it so the speakers and headphones are on at the same time, so there has to be a setting that will revert it back to "normal" operation of the headphone jack connection muting the speakers.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Yes, that was the problem I had when I first got the system. That's why I included that window in the shot. I've been toggling it back and forth, but either way, the headphones still work. Still can't get them separated except for how I explained.
circa Oct 2006,
Dell XPS M1210,
3.25 (4) GB of RAM,
