Windows 7: No sound PLEASE HELP...
24 Feb 2012   #1
Crimsoneye
windows 7 32bit
My computer has no sound coming from it. I've tried uninstalling and reinstalling it. All I have to choose from in playback devices is Digital Audio (HDMI). My friends were unable to help, they could hear me but I hear no sounds at all, even though the bar says that sounds are being made. I'm out of ideas, and I am well versed in device manager and the such. Everything says they are working properly. No my sound is not muted, or low.
Windows 7 32 bit.
24 Feb 2012   #2
StalkeR
Windows 7 Ultimate SP1 / 10 Pro x64
We need specs about your system. Fill the specs, using this method: How to - System Specs
If you are using Realtek drivers, take a look at this thread: Latest Realtek HD Audio Driver Version
25 Feb 2012   #3
carwiz
Windows 7 Pro-x64
Quote   Quote: Originally Posted by Crimsoneye View Post
What computer?
Uninstalling and reinstalling what?
This would indicate you have chosen digital audio output as the default device. Do you have an external receiver or amplifier with speakers connected to your computer?
Open the Playback devices window. Right click in an open area of the list of devices then check both boxes. Does the Speakers entry show up now? If it does, select it, enable then set as the default device.
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
