Windows 7 Forums Search
Windows 7 - Creative Sound Cards.
10-30-2009   #21
windows 7 home premium 64 bit
took my speaker kit back and got a new set, no distortion there but can only get sound through front 2 speakers and not the other 3. works with my older set still when i try that through the realtek on board, but only sub and 2 speakers
ive uninstalled all the drivers from creative and tried with the others, it picks my sound card up, but when i try to get into the media centre for the eax settings and any of that is say it did not find a device supported by this product. mite just get that xonar dx, you got an official link for where you got the driver from as on microsoft compatibility page it says it dont need 1
11-01-2009   #22
windows 7 home premium 64bit
ive tried all ideas, and i had my speakers working for a few hours on saturday afternoon, then after a restart after installing a programme, they failed to work again... is this just the way things will be until creative bring out an actual windows 7 driver that isnt a beta? or will i have to system reload to the point at which the soundcard worked?
11-03-2009   #23
Windows 7, Linux
KX Audio Drivers [emu10k1]
Don't forget the KX drivers for emu10k1 and emu10k2 (all SBL and most audigy)
11-04-2009   #24
Windows Vista Pro 64 & Windows 7 Pro 64
X-FI Auzen Pack / working Beta-Driver
My x-fi music works great with XFI_AuzenUAA_1_0.exe, which includes already the beta1-device-driver
11-09-2009   #25
Lonelobo
I’m having trouble with installing the x-fi titanium drivers on my windows 7 home premium x64 nl. When I run the installer it says that there is no creative compatible device found. When I use the at disk method and locate to the file wdma_emu.inf, it says (rough translated from Dutch:
“The map doesn’t contain a compatible driver for ‘re device. Check if the driver works on a x64 pc when there is a driver in the map”.
What shoud I do to get my x-fi work. It is a clean win 7 instal.
11-09-2009   #26
Windows 7 Ultimate 64bit
I have big troubles every time i start an application or i reboot my pc the audio will vanish again
I have a clean install of windows so i don't really know, the audio card also make my pc fail the boot today until i've uninstalled it
11-09-2009   #27
my card still isnt working, below is a list of my pc specs...
im currently uninstalling all sound drivers and programs from my pc in the hope that i can fix this problem, ive tried all previous ideas, and some have worked for a few hours then failed and others have lead me further away from a solution, so does anyone else have any ideas for what i can do?
specs:
CPU AMD Athlon 64 6000+ AM2
MB Asus M2N-E SLi
RAM 4Gb (2x2Gb)
GPU XFX 8600GT 256mb
2x standard IDE optical drives
HDD 1x 160Gb (main boot) + 1x 300Gb (backup and media)
hope that this can help solve my problem,
many thanks
Oliver
update, all drivers and creative programs now wiped from pc, square 1
11-10-2009   #28
Windows 7 and Windows XP dual boot
Installed Windows 7 Home Premium last night. Made my PC a dual boot with Windows XP. Soundblaster XFi Extreme Fidelity works just fine in XP mode and I have both Media Player 5 and Craetive Console working. Installed the latest drivers from Creative download site. I do get sound, but it's via Windows Media Player. No individual speaker control, no sub woofer. If I right click on the windows media player screen I have access to many of the functions Creative Media Console has in XP mode, but no speaker control, no speaker check. I prefer Creative's Media Player to the windows player and I would like to get full audio control back. Anyone have a suggestion?
11-12-2009   #29
Please help with my thread storm
Please help with my thread storm: Sound Blaster Audigy 2 isn't nearly as loud in Win 7
11-12-2009   #30
Please help with my thread stormy13: Sound Blaster Audigy 2 isn't nearly as loud in Win 7
 Creative Sound Cards. problems?
Similar Threads for: Creative Sound Cards.
Solved Pax Drivers for Creative Sound Cards Sound & Audio
Creative Sound Blaster Audigy 24bit Sound Card Drivers
June 2010 Drivers for EMU20k1 XFI cards (PCI) on the creative site. Sound & Audio
Non Creative Labs Sound cards Sound & Audio
Creative Sound Blaster 5.1 - digital out no sound Sound & Audio
