Creative Sound Cards.
Page 14 of 21 FirstFirst ... 41213141516 ... LastLast
  1. Posts : 3
    please help
    I have creative sound blaster 128D i cant able to install it in windows 7 please help me.
  2. Posts : 6,879
    Win 7 Ultimate x64
       #132
    gudia, welcome to the forums.
    If that card is what I think it is the chances of any driver for it is slim to none.
    Would help to know exactly which card it is. Easiest would be to pull the card and locate the model number, should be along the top edge of the card and should look like either SBxxxx or CTxxxx.
  3. Posts : 7,683
    Windows 10 Pro
       #133
    Yeah, If it's what I think it is a well we're talking about a 12 year old card, and well, as stated above, drivers for that is slim to none but closer to none.
    BTW does is look like this....
    creative sound blaster 128D - Google Search
  4. Posts : 3
    yeah this is.
    Yes this is my card i know its to old but i jst have it can you help me to install it?
  5. Posts : 7,683
    Windows 10 Pro
       #135
    I'm sorry to say but there are no Windows 7 drivers for that card, thus I can't help you install it without them.
    Sorry
    However answering stormy's question....
    might provide a little hope, though I doubt it given the age of the card.
    Good luck.
  6. Posts : 6,879
    Win 7 Ultimate x64
       #136
    About that best you can hope for for that old card is to try and install the last XP driver for it,
    Creative Worldwide Support > Sound Blaster PCI 128
    using compatibility mode,
    Compatibility Mode
    Is the rest of the computer of similar vintage, or is it newer? Depending on what you have you would probably be better of using the onboard sound.
  7. Posts : 1
    Windows 7 32 bit
       #137
    X-fi audio extreme 'disappears' in Windows 7
    I have the most up to date driver for the x-fi extreme and Windows 7 recognizes it when I reboot. But after some period of time (usually a few hours), it disappears from the device manager and can't be found. The only way I can recover it is to reboot again. Is there any way to keep it as recognized? has anyone else run into this problem? Thanks.
  8. Posts : 3
    thank you i will buy a new card
  9. Posts : 1
    Alright, I've read every post here and I feel as if I am experiencing a problem slightly different than anyone else.
    I have an on-board Creative sound card (Sound Blaster X-Fi Xtreme Audio on a MSI P6N Diamond motherboard) and have successfully installed the audio drivers to a point where I can hear audio. Where the problem is, though, is the microphone is being sensed backwards.
    For example: My microphone jack in the rear of my computer currently has nothing plugged into it, yet the status says that something is plugged into it. If I were to plug a standard microphone into the jack, the computer switches the recognition to "Not plugged in" and will not receive signals from the microphone.
    I have tried using the Creative Audio Control Panel to switch the FlexiJack settings between "Line in" and "Microphone" but nothing will change the fact that the computer is recognizing the inputs backwards.
    Any advise will be greatly appreciated.
  10. Posts : 6
    Win 7 Ultimate 32bit
       #140
    stormy Plz help! SB Audigy 2 Software suite
    hello everyone, i need a complete software suite for my creative SB audigy 2 win 7 32bit and 64bit supported...that is having EAX console and surround mixer n all others..plzz help me guide me...;-(
