Realtek AC'97 Audio (Code 10)
  1. Posts : 34
    Windows XP and Windows 7
    Thank you :) will keep you posted on whether this works for me.
  2. Posts : 34
       #12
    How do I install these drivers?
    I've tried to install them through Device manager but its still comign up with code ten, and failed to install
  3. Posts : 336
    windows 7 X64
    my buddy has the same problem tried using conaxent ac link or whatever drivers and it comes in really choppy
  4. Posts : 34
       #14
    Atm the moment I'm downloading these, not sure how they'll do but anything is worth a try.
    New Realtek AC'97 audio drivers for Vista x64 - Windows x64 Edition
  5. Posts : 336
    windows 7 X64
       #15
    what model is your pc?
  6. Posts : 34
       #16
    Model? If you mean like is it built by Dell or something, I can't give you that information because its pretty much home built
    To install a driver manually its still done through device manager but I select a folder correct?
  7. Posts : 336
    windows 7 X64
       #17
    oh i see, i was just trying to figure out it was the same sound card as my buddys but if its a desktop chances are no.
  8. Posts : 995
    XP/win7 x86 build 7127
       #18
    ahh, i failed to realize that you were on x64.... my reply/links were for x86... atleast thats what i have tested on
  9. Posts : 8
    Windows (XP Home Ed, Vista Home Premium, 7)
       #19
    Same error here! Would there be anything we could do to get 5.1 sound back?
  10. Posts : 2
    Realtek AC-097 code (10)
    I have tried all the links to fix my NO AUDIO. Nothing works. I can not find the R2.14, it must be superseeded. I hve an HP zv5330us and I had both Realtek and Soundmax. When I went to Vista I had to remove Realtek, in the registry also. Then SoundMax was great. Went to 7 and not hearing a thing. Any idea where I should look for a remedy? Whenever I go to the HP site it basically tells me to buy a new computer.
