| Windows 7: Realtek AC'97 Audio (Code 10) |
15 Jan 2009
#1 | | |
Realtek AC'97 Audio (Code 10) I have a HP Pavilion zv6000
amd 64 3200 +
I used the Realtek AC'97 Audio driver when I had x64 vista business and the sound worked fine.
I used the same driver with Windows 7 and I get and error that says This device cannot start. (Code 10)
Has anyone had luck fixing this issue or had the same problem. | My System Specs |
| System Manufacturer/Model Number HP Pavilion zv6000 OS windows 7 x64 CPU AMD 64 3200+ Memory 1.5 gig Graphics Card ATI Radeon Xpress 200m Screen Resolution 1200 x 800 |
16 Jan 2009
#2 | | Windows 7 beta 1, win xp home |
i had a problem with my ac'97, not sure if that was the error code, but it was saying i had no audio installed, have you tried the lastest version from the website? i am running 6.01.6293 (16/09/2008) and after installing this version it was OK
Quote: Originally Posted by billdobeans I have a HP Pavilion zv6000
amd 64 3200 +
Has anyone had luck fixing this issue or had the same problem. | My System Specs | | OS Windows 7 beta 1, win xp home |
16 Jan 2009
#3 | | |
Any luck? Can you post the link to that driver (6.01.6293)? I'd like to test. (pvaillion zv5000)
Thanks | My System Specs | | |
16 Jan 2009
#4 | | Windows 7 beta 1, win xp home |
ftp://202.65.194.211/pc/audio/6285_Vista_APO_PG536.zip
although the file date looks outdated on the website.
i just checked my windows update history and it appears windows updated it after i installed the above:
Realtek Semiconductor Corp. driver update for Realtek AC'97 Audio for VIA (R) Audio Controller
Installation date: 12/01/2009 12:20 AM
Installation status: Successful
Update type: Optional
This driver was provided by Realtek Semiconductor Corp. for support of Realtek AC'97 Audio for VIA (R) Audio Controller
More information: Winqual Help
Help and Support: Select a Product Solution Center | My System Specs | | OS Windows 7 beta 1, win xp home |
16 Jan 2009
#5 | | |
no sound on realtec one more option to check is in control panel, find the sound option and make sure the output you intend to use is set to on and/or is the default. I am noticing a trend (good) that some defaults are set to off, which is what I found for the digital output on my pc.
hope this helps, so far I am very impressed, moreso than the vista beta | My System Specs | | System Manufacturer/Model Number hp9130e, xps 8300, acer aspire 563o OS windwos 7 beta CPU 920, i5 2400, mobile 5200 c2d Memory 9gb, 6gb, 4gb Graphics Card amd 6870, ati 5770, go 7300 |
25 Jan 2009
#6 | | Windows 7 6.1.7000 32 bit Orange Park, FL |
I too am having the same error code 10. I have the latest driver both form Realtek & from Windows Update. Installs fine, reboots, and still error 10. Sounds in Control Panel shows no audio device detected. Any more ideas? Onboard sound Realtek VIA AC97 on a PC Chips M811LU Athlon 1800 1.5Gb DDR | My System Specs | | System Manufacturer/Model Number Homegrown OS Windows 7 6.1.7000 32 bit CPU Athlon XP 1800 Motherboard PC Chips 811LU Memory 1.5Gb DDR Graphics Card nVidia GeForce 5200 Monitor(s) Displays 15" LCD Screen Resolution 1024x768 Hard Drives Seagate 80Gb Internet Speed 3meg DSL |
26 Jan 2009
#7 | | Windows 7 beta 1, win xp home |
have you tried deleting the device from device manager and then rescanning for new hardware?
i have solved a few problems with onboard devices using this method. other than that, ia am out of ideas. | My System Specs | | OS Windows 7 beta 1, win xp home |
26 Jan 2009
#8 | | |
something happened here with this driver. On initial install Windows 7 installed the driver just fine.... then after some play with windows, installing other programs, non audio-type but plenty of other drivers and such, the sound failed to work.
Even an uninstall or update drivers did not work of course. MS still said it had the best drivers and device was working properly. Well, no it wasnt.
I had this same sorta problem on laptop. Windows 7 only wanted to install the HD realtek drivers. That gave me no sound at all.
Eventually i tried and tested a few other drivers to find out the best one out there is the Vista_R12.zip from Realteks website. I tried the "Vista APO" driver, but it didnt work true for me, while the R12 worked without a hitch. | My System Specs | | System Manufacturer/Model Number CUSTOM OS XP/win7 x86 build 7127 CPU Athlon64 X2 DUAL 4200+ 2.21ghz Motherboard ASUS K8 PRO SLI Memory 2GB Dual Chan DDR2 Corsair Graphics Card Nvidia 6800GT Sound Card nvidia Monitor(s) Displays 19' LCD Screen Resolution 1280x1024 Keyboard MS wireless Mouse MS Wireless PSU coolermaster 450 Case SUPERFLOWER Cooling 1 HDD bay fan, 5x80mm Case Fans, AEROGATE II Fan/Temp Hard Drives WD 250, 2x500, 2x1TB IDE/USB
WD 250 SATA (system)
SEAGATE 120 Sata Internet Speed fassssssssst |
27 Jan 2009
#9 | | |
I have this same issue, for some reason any driver I download does not work Code 10 error time after time. http://www.realtek.com.tw/downloads/...&GetDown=false
Should this work? | My System Specs | | System Manufacturer/Model Number Home-built, 5 years ago. OS Windows XP and Windows 7 CPU 2GHz Intel Celeron Motherboard Too old to mention. Memory 1.5gb Graphics Card 256mb Radeon 9600pro Sound Card Inbuilt C-media Realtek AC-97 Monitor(s) Displays Dual Monitors - Dell 19" and a Hp Pavilion 19" Screen Resolution 1440 by 900 & 1280 by 1024 Keyboard PC Direct! Case Old, unamable Hard Drives 250gb + 40gb. Seagate. Internet Speed 512kbps |
28 Jan 2009
#10 | | |
Here is the link for the vista driver R2.14. Dated 2009/1/9 http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
I have found this to work with no problem. Also has the 3D SoundBack beta 0.1 (audio effect/enhancement for Vista) not tested by me yet. | My System Specs | | System Manufacturer/Model Number CUSTOM OS XP/win7 x86 build 7127 CPU Athlon64 X2 DUAL 4200+ 2.21ghz Motherboard ASUS K8 PRO SLI Memory 2GB Dual Chan DDR2 Corsair Graphics Card Nvidia 6800GT Sound Card nvidia Monitor(s) Displays 19' LCD Screen Resolution 1280x1024 Keyboard MS wireless Mouse MS Wireless PSU coolermaster 450 Case SUPERFLOWER Cooling 1 HDD bay fan, 5x80mm Case Fans, AEROGATE II Fan/Temp Hard Drives WD 250, 2x500, 2x1TB IDE/USB
SEAGATE 120 Sata Internet Speed fassssssssst Realtek AC'97 Audio (Code 10) problems? All times are GMT -5. The time now is 07:52 AM. | |
