Windows 7: Red X on Volume Icon, "No Audio Output Device is installed."
07 Mar 2012   #1
nicoricarte
Hey, guys.
I've been having that problem for a while now, but I could always just system restore back to a previous state and my sound comes back. But now, it seems that when I tried to do a system restore, one wasn't available.
I've done everything that I've searched on, like disabling/enabling sound card, uninstalling and installing again. None of those seems to work.
Since my system restore sets it back before an update is installed, then I think it's because of an update. And the most recent update since the Red X was an update for windows defender, and I can't uninstall the update, or whatnot.
I'm getting really desperate here, guys. Please help.
Thanks in advance.
I run Windows 7 Home Premium x64.
The sound card is Conexant SmartAudio HD.
10 Mar 2012   #2
IIllytch321
If it's a Windows Update you should be able to uninstall it, at least if you remember what number it was exactly. "Control Panel" > "Programs and Features" then at the top left click on "View installed updates", the updates you installed, at least via Windows Update, should now be viewable. Then find which one it was and uninstall it, should be easy enough.
So Windows isn't acknowledging your sound card in "Device Manager"? If not go to Conexant's website and search under "Audio Solutions" or google for any drivers that may suit your exact product. If it is acknowledging your card. . .I don't know. If it's not onboard then it wouldn't be able to be disabled in your BIOS, unless you have an onboard sound AND a sound card, and they're conflicting? If so you might have to disable the onboard audio perhaps?
need "always on top icon & msg for "default audio input/output device"
I need to always display the default audio input and audio output device currently on win7. Would like to launch a small program on change as well or instead. I tried to use task scheduler but was not able. Help! Thanks, Ray
Sony VAIO laptop "No Audio Output Device Installed"
Warning, I am NOT a computer person at all, but have spoken to some and tried several repairs. I have a Sony VAIO VPCEA24FM laptop, running windows 7 64-bit and the sound has randomly stopped working (made no changes to anything that I know of). There is a red circle with an x in it on the volume...
Sound error "no audio output device is installed"
Recently when I was trying to enable my sound card so I could make YouTube videos, I managed to somehow break my sound. I have a windows 7 64bit computer that runs realtek hd audio and nvidia hd audio. I have tried reinstalling windows and that does not work, as it comes up with an error message...
Sony VGN-FZ21Z "no audio output device installed"
Hello All, I am sorry if this has been addressed but I have been looking everywhere and have tried so many things to resolve this issue to no avail. My Sony laptop VGN-FZ21Z VISTA home premium 32 bit has a little red x next to the audio on the bottom right toolbar. No Audio output device is...
Drivers
Acer Aspire 3690 w/ Conexant: "No Audio Output Device is installed"
Greetings and salutations. I recently upgraded an Acer Aspire 3690 to Windows 7 (32bit) and everything went well, almost. See, for life of me I can't get audio to work. (That old chestnut.) The speaker icon in the notification area displays the white cross/red circle and informs me that "No...
Audio stops working, "No Audio Output Device Installed"
I'm running a Dell XPS 420, which came with Windows Vista. I decided this morning that I was going to give Windows 7 a try, backed up some media on another PC, and did a completely fresh install. Everything worked perfectly, I didn't even have to install any drivers. My native resolution was...
