Master volume does not control USB speakers
  1. Posts : 10
    Windows 7 ultimate x32
    I connected a DAC to my laptop and set it as the default device from the control panel. Now the master volume mixer does not work at all.
    When I change change the "master volume" slider - the others (WMP, firefox, etc...) apparently change with it too but there is no effect on the actual volume. But when I change each individual mixer it does.
    How do I fix the master volume so that it works as normal? Any help is appreciated.
  2. Posts : 2,362
    Win7 H.Prem. 32bit+SP1
    Hi nonyabus,
    from control panel, select 'Sound' highlight speakers then 'Configure'
  3. Posts : 10
    I did. Still the master volume slider doesn't do anything, but all the other ones work...
    When I change the first one all the others *appear* to change with it, but there is no effect on the actual volume.
  4. Posts : 2,362
    I use the volume switch on my speakers.
  5. Posts : 10
    I'm using headphones... no volume knob.
  6. Posts : 2,362
    If their not too expensive, buy a better set.
  7. Posts : 10
    Are you serious... they're HD580s, and the DAC alone is 500$. Is there a real solution?
