Windows 7 Forums Search
Windows 7 - Realtek HD Changing Jack output reassignments ( FIX )
01-22-2010   #101
I changed the binary values but no effect on playback. I have the most recent drivers, 5.1 enabled and speakers work just fine in hd audio manager, but not elsewhere. Any help on this issue?
02-20-2010   #102
Windows 7 x64 RTM
Quote   Quote: Originally Posted by xyakaix View Post
Give the OS a restart after making the changes to the binary values.
I have changed the rear and center/subwoofer to front , restart , everithing works fine.
I donno if it`s like speaker fill but sounds great.
02-26-2010   #103
Windows 7 x64 RTM
Installed the latest Realtek drivers R 2.43 , still no 5.1 sound with the default values in registry.
02-26-2010   #104
Front jack for Speakers - Do not work/Win 7
Hi Everyone
I have Windows 7 installed in my PC and the front jack for speakers doesnt work however the same will work in Vista/XP any help is highly appreciated.
Thanx in advance.........
02-27-2010   #105
Windows 7 x64 RTM
Change the jack output from regdit. Check the first post.
Is there a way to quickly change the jack output without having to restart the PC? A .reg file of some sort.
02-28-2010   #106
Yes, I showed a way to change it without restarting. Check my first post on page 10.
03-01-2010   #107
Windows 7 x64 RTM
Quote   Quote: Originally Posted by Pulover View Post
Thanks a lot , that worked like a charm.
03-01-2010   #108
win7x64
oh, thank god for this solution. this problem kept me up until 5am last night.
i changed side port to headphones(or front speakers) and it works like charm.
anyway, this problem is pretty stupid. i didnt think that someone like realtek could have basic problem like this for so many months. it worked normaly in winXP :/
03-02-2010   #109
Quote   Quote: Originally Posted by lamzor View Post
In fact, this problem is due to the lack of direct sound in the new windows architecture. Realtek does have a beta solution, which is 3D SoundBack, it restores surround but you have to assign every app you want it to work on (also, it's built for vista and must be run in compatibility mode on seven).
Nevertheless Creative have a solution to this, but you have to buy their software or one of their soundcards. I agree that Realtek should have this solved by now.
03-08-2010   #110
Windows 7 Home Premium
Quote   Quote: Originally Posted by petrossa View Post
This little try-out should work, it's for all audiocards
www.petrossa.com/AudioEndpoints.zip
Hey - thanks for this. I am not sure if this is what I am looking for. All I want is 2 or 3 simulataneous outputs of decent stereo sound. I can use a hardware splitter. I do not need digital audio or surround but may at some time in the near future.
Right now I have one splitter out of the rear green audio speaker output (don't go by the pic) and one cable out of the front headphones port. The problem is that when I plug in the headphone cable it shuts off the speakers. I can't find the option to disable this.
My workaround is to use software Virtual Audio Cable (VAC) but that has a lot of complications and I'd like to uninstall it.
I attached a snapshot of my audio devices, my rear audio jacks and my driver details.
Is your software or the reg settings a way of solving my issue? I guess if I can assign regular stereo output to 3 of the rear 3.5mm ports at the same time that would be ideal.
Realtek HD Changing Jack output reassignments ( FIX )-audio3.jpg   Realtek HD Changing Jack output reassignments ( FIX )-audiodevices.jpg   Realtek HD Changing Jack output reassignments ( FIX )-realtekdriver.jpg
Similar Threads for: Realtek HD Changing Jack output reassignments ( FIX )
Win 7 & Realtek HD Stereomix: No output... or is it input? Sound & Audio
Earphone jack output setting? Sound & Audio
less /unsatisfied sound output of realtek alc 892 Sound & Audio
Realtek Digital Output Problem Sound & Audio
can't set front jack as default audio output (notebook) Sound & Audio
