Windows 7 Forums Search
Windows 7 - Realtek HD Changing Jack output reassignments ( FIX )
04-12-2009   #11
Win 7
Quote   Quote: Originally Posted by MaDMaxiBo View Post
Hi
Can i solve my problem with this options ?
problem is this ...My front audio output is not working...
it says not attached even i put headphone in...
i thought may be i can change rear autput with front...What should i do ?
Wouldn't hurt to try, but i would try the latest drivers first if you have not.
04-13-2009   #12
Windows 7 x64 7000
Quote   Quote: Originally Posted by YupYup View Post
im using latest driver. R 2.21
and i dont have the codes : DevType_0888_SS147b1083
i added manually and this is how it seems : What else can i do ? fornt jack still doesnt work.
04-13-2009   #13
Win 7
You want the Drv5821_DevType_0885_SS1458a002 key.
04-13-2009   #14
Windows 7 x64 7000
i quit..
i realized that there is nothing to do with regs for my problem...
just jack is not working.
Thanks anyway.
04-23-2009   #15
windows 7 64 bit and windows vista 64 bit
thru software i am able to do this.. realtek software u can choose which pin to act aas what.. u can even interchange mic with head phone.. front with back.. anyway u want..
and its simple and very easy ..
this is like.. all techhy
04-23-2009   #16
Win 7
Quote   Quote: Originally Posted by mustang View Post
This "techy" thread is for those who can't get it to work through the software.
04-30-2009   #17
Windows 7 Professional x64
Quote   Quote: Originally Posted by Neilsouth View Post
Atleast now i can change the ports by editing the Pin binary numbers! . If you can't change jack output assignment this will fix it oh and it sounds great ., i turned my Center/Subwoofer to front speaker out put so my rears are stereo just like my fronts and not speaker filled rubbish
Neilsouth can you tell me how did you get the sounds from the rear speakers without using the speaker fill option can you explain it 2 me cz i speaker fill sound suckz
05-02-2009   #18
I have a big problem now. Yersterday, I installed my windows 7 RC1 7100. And no sound.
I have checked the sound driver several times, and it doesnt work at all although I have plugged my speaker in. Uninstall then reinstall. OMG. Here is my problem, help me:
I have tried the regedit method, but I cannot find the way to the address.:
05-02-2009   #19
Someone helps me. Pls.
05-05-2009   #20
vista x64/ win 7 x64
I wrote a little thing to set Audio endpoint on the RealtTek HD without setting registry settings. Win 7 finally lets us set endpoints on the fly without restarting the apps, the little app will let you change audio endpoints system wide, either with the gui or with commandline switches
It's really hardwired for English only:
http://www.petrossa.com/SetRealtek.rar
or the source on codeproject
CodeProject: Set Audio Endpoints System Wide Vista/Windows 7. Free source code and programming help
Similar Threads for: Realtek HD Changing Jack output reassignments ( FIX )
Win 7 & Realtek HD Stereomix: No output... or is it input? Sound & Audio
Earphone jack output setting? Sound & Audio
less /unsatisfied sound output of realtek alc 892 Sound & Audio
Realtek Digital Output Problem Sound & Audio
can't set front jack as default audio output (notebook) Sound & Audio
