Realtek HD Changing Jack output reassignments ( FIX )
Page 1 of 21 12311 ... LastLast
  1. Posts : 123
    Win 7 Ultimate 64 RTM
    Mappings are saved in the following location "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0000\Settings\DevType_0888_SS147b1083 or ending in DevType_0885_SS18490890
    "Pin00" = Rear Green-Coded "FR FL" jack
    "Pin01" = Rear black-coded "RR RL" jack
    "Pin02" = Center/Subwoofer
    "Pin04" = Mic-In
    "01 00 00 00" = Mic-in
    "02 00 00 00" = headphones
    "04 00 00 00" = Front speakers
    "05 00 00 00" = Rear speakers
    "06 00 00 00" = Center/subwoofer
    "07 00 00 00" = Side speakers
    Example if i want "Pin01" = rear black-coded "RR RL" jack to be front speakers all i have to do is Pin01 - 04 00 00 00.
    Atleast now i can change the ports by editing the Pin binary numbers! . If you can't change jack output assignment this will fix it oh and it sounds great ., i turned my Center/Subwoofer to front speaker out put so my rears are stereo just like my fronts and not speaker filled rubbish
  2. Posts : 4,364
    Windows 11 21H2 Current build
    Repped & Sitckified
  3. Posts : 123
    Hey thanks man :)
  4. Posts : 2
    windows 7
    wer do i write this ..specify the location pls
    "Pin04" = Mic-In
  5. Posts : 2
    windows 7
    i cant find this pls help me out
  6. Posts : 2
    "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0000\Settings\DevType_0888_SS147b1083 or ending in DevType_0885_SS18490890"
    This path does not exist on my installation.. I get to settings but there is no DevType_xxxxxx folder.
    Any one know?
  7. Posts : 2
    File can't be found
    Hi there, your fix worked PERFECTLY for me when I was using Vista. One of my audio pins broke off in the front speakers jack of my mobo, so I was using your fix to make the rear speakers jack act as the front speakers. HOWEVER, now that I have installed Windows 7, the registry file isn't there! I have tried installing my old drivers along with the new (supposedly Windows 7 compatable) drivers with no luck. Here is all that I can find; it would be great if I could get some help.
    Attached Thumbnails Attached Thumbnails Realtek HD Changing Jack output reassignments ( FIX )-help.jpg
  8. Posts : 910
    Win 7
    If you are running the latest realtek drivers and don't see the keys just add them(right click, new binary value).
  9. Posts : 2
    YES Thank you very much, YupYup. This worked perfectly!
  10. Posts : 12
    Windows 7 x64 7000
    Hi
    Can i solve my problem with this options ?
    problem is this ...My front audio output is not working...
    it says not attached even i put headphone in...
    i thought may be i can change rear autput with front...What should i do ?
    Attached Thumbnails Attached Thumbnails Realtek HD Changing Jack output reassignments ( FIX )-ado.jpg
