#91
Just wanted to say thanks! I've been looking for a soloution to this for a long time! <3
A small tip to something that threw me off: (for people with an AW9d motherboard at least)
If you can't see "Pin01" etc. You will have to re-plug it and then refresh the window.
example; if you want to switch rear black into rear green.
Plug the cable into the green socket and press f5, then the pin will appear, then plug it in to the black socket and hit "f5" again and that pin will appear aswell.
Then just change the valuable of the last "PinXX" to the first "PinXX", Restart your computer, and you're golden :)
