Realtek HD Changing Jack output reassignments ( FIX )
Neilsouth
4:01 AM
Mappings are saved in the following location "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0000\Settings\DevType_0888_SS147b1083 or ending in DevType_0885_SS18490890
"Pin00" = Rear Green-Coded "FR FL" jack
"Pin01" = Rear black-coded "RR RL" jack
"Pin02" = Center/Subwoofer
"Pin04" = Mic-In
"01 00 00 00" = Mic-in
"02 00 00 00" = headphones
"04 00 00 00" = Front speakers
"05 00 00 00" = Rear speakers
"06 00 00 00" = Center/subwoofer
"07 00 00 00" = Side speakers
Example if i want "Pin01" = rear black-coded "RR RL" jack to be front speakers all i have to do is Pin01 - 04 00 00 00.
Atleast now i can change the ports by editing the Pin binary numbers! . If you can't change jack output assignment this will fix it :D oh and it sounds great :D., i turned my Center/Subwoofer to front speaker out put so my rears are stereo just like my fronts and not speaker filled rubbish
Win 7 Ultimate 64 RTMQ6600 @ 3.03GHZ8GB @ 338MHZPalit GTX260 @ 707/1544/1200
Q6600 @ 3.03GHZ
ASRock Penryn1600SLI-110d
8GB @ 338MHZ
[4.1 ] - Creative Labs XFI-GAMER
SyncMaster T240 24" Dvi/HDMi
1920x1200
Hitachi 500GB
Winpower 750Watt
Thermaltake Soprano
Oem Cooler
HP Keyboard
Optical Microsoft Mouse
3MBIT 350kb/s+
Repped & Sitckified
    Windows 11 21H2 Current buildAMD Ryzen 9 3950X4 * 32 GB - Corsair Vengeance 3600 MHzEVGA GeForce RTX 3080 Ti XC3 ULTRA GAMING (12...
    The Beast Model A (homebrew)
    AMD Ryzen 9 3950X
    MSI MEG X570 GODLIKE
    Realtek® ALC1220 Codec
    3x 3840 x 2160
    SteelSeries Apex Pro
    Windows Defender + MB 3
    ChromeOS Flex Dev Channel (current)Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz, 250...16 GBIntel(R) HD Graphics 520
    Dell Latitude E5470
    16 GB
    Dell laptop display 15"
    1920 * 1080
    Toshiba 128GB M.2 22300 drive
Hey thanks man :)
Q6600 @ 3.03GHZ
8GB @ 338MHZ
1920x1200
Hitachi 500GB
Winpower 750Watt
Thermaltake Soprano
Oem Cooler
HP Keyboard
3MBIT 350kb/s+
wer do i write this ..specify the location pls
"Pin04" = Mic-In
windows 7
windows 7
i cant find this pls help me out
windows 7
windows 7
"HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0000\Settings\DevType_0888_SS147b1083 or ending in DevType_0885_SS18490890"
This path does not exist on my installation.. I get to settings but there is no DevType_xxxxxx folder.
Any one know?
File can't be found
Hi there, your fix worked PERFECTLY for me when I was using Vista. One of my audio pins broke off in the front speakers jack of my mobo, so I was using your fix to make the rear speakers jack act as the front speakers. HOWEVER, now that I have installed Windows 7, the registry file isn't there! I have tried installing my old drivers along with the new (supposedly Windows 7 compatable) drivers with no luck. Here is all that I can find; it would be great if I could get some help.
If you are running the latest realtek drivers and don't see the keys just add them(right click, new binary value).
Win 7
Win 7
YES Thank you very much, YupYup. This worked perfectly!
Hi
Can i solve my problem with this options ?
problem is this ...My front audio output is not working...
it says not attached even i put headphone in...
i thought may be i can change rear autput with front...What should i do ?
Windows 7 x64 7000
Windows 7 x64 7000
Hi
Wouldn't hurt to try, but i would try the latest drivers first if you have not.
Win 7
Win 7
im using latest driver. R 2.21
and i dont have the codes : DevType_0888_SS147b1083
i added manually and this is how it seems : What else can i do ? fornt jack still doesnt work.
Windows 7 x64 7000
Windows 7 x64 7000
You want the Drv5821_DevType_0885_SS1458a002 key.
Win 7
Win 7
i quit..
i realized that there is nothing to do with regs for my problem...
just jack is not working.
Thanks anyway.
Windows 7 x64 7000
Windows 7 x64 7000
thru software i am able to do this.. realtek software u can choose which pin to act aas what.. u can even interchange mic with head phone.. front with back.. anyway u want..
and its simple and very easy .. :(
this is like.. all techhy
windows 7 64 bit and windows vista 64 bitIntel Core 2 duo E8500 3.16 ghz.. but running...2045 Gb ddr2..ati radeon- 4800.. was this a good one??
XUSTOM
Intel Core 2 duo E8500 3.16 ghz.. but running at 3.5 ghz
EP35..gigabyte.. the new one which got outdated cause of p45
2045 Gb ddr2..
built in
Philips 19 inch lcd.. wished i had bains to get 21
1400 x 900
1. sata 500 gb.. splited into 3
whn adding the total disk space,, it totals upto 464.3 gb ??
where's the rest!! HEEELP
dont know what psu means.. hey any one can u help me here
Thermaltake.. the coolest one.. reaallly looks cool
normal ..what shud i know to put liquid cooling system?
microsofy wireless..default driver gaming lags..update=Good
microsoft bindeled wiless Keyboard mouse.. cheapest one
! mb.. in utorrent why is my upload max 20 KB??
ANYone willing to help me sort my confused state for hardware??
This "techy" thread is for those who can't get it to work through the software.
Win 7
Win 7
Neilsouth can you tell me how did you get the sounds from the rear speakers without using the speaker fill option can you explain it 2 me cz i speaker fill sound suckz
Windows 7 Professional x64Intel E4600 2.40 GhzKingston (2+1)GB DDR2 667MHzXFX ATI 4840 HD 512MB
Intel DG33FB
Realtek Onboard
HP w17e 17 nich Wide Screen LCD
1400x900
500GB Seagate Barracuda 7200.11 Sata II
Amacrox 500W True Power AX 500-S
CM Hyper TX3
A4Tech Basic Keyboard
A4Tech G7 Wireless
I have a big problem now. Yersterday, I installed my windows 7 RC1 7100. And no sound.
I have checked the sound driver several times, and it doesnt work at all although I have plugged my speaker in. Uninstall then reinstall. OMG. Here is my problem, help me:
I have tried the regedit method, but I cannot find the way to the address.:
Someone helps me. Pls.
vista x64/ win 7 x64phenom 9950 BE8 gbnvidia gts 250
me and myself
phenom 9950 BE
ASUS M2A-VM HDMI
8 gb
nvidia gts 250
realtek HD onboard
dual hd 19" tft
2 x 500 gb WDC
1 x 500 gb Seagate
1 x 1000 gb Seagate
1 80 gb raptor
1 usb 160 gb
standard issue
logitech g11
usb wireless MS laser 6000
18 mb (according to my provider :)
