Neilsouth
- Local time
- 2:33 PM
- Messages
- 123
Mappings are saved in the following location "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0000\Settings\DevType_0888_SS147b1083 or ending in DevType_0885_SS18490890
"Pin00" = Rear Green-Coded "FR FL" jack
"Pin01" = Rear black-coded "RR RL" jack
"Pin02" = Center/Subwoofer
"Pin04" = Mic-In
"01 00 00 00" = Mic-in
"02 00 00 00" = headphones
"04 00 00 00" = Front speakers
"05 00 00 00" = Rear speakers
"06 00 00 00" = Center/subwoofer
"07 00 00 00" = Side speakers
Example if i want "Pin01" = rear black-coded "RR RL" jack to be front speakers all i have to do is Pin01 - 04 00 00 00.
Atleast now i can change the ports by editing the Pin binary numbers! . If you can't change jack output assignment this will fix it
oh and it sounds great
., i turned my Center/Subwoofer to front speaker out put so my rears are stereo just like my fronts and not speaker filled rubbish
"Pin04" = Mic-In
Win 7 Ultimate 64 RTMQ6600 @ 3.03GHZ8GB @ 338MHZPalit GTX260 @ 707/1544/1200
- Win 7 Ultimate 64 RTM
- Q6600 @ 3.03GHZ
- Motherboard
- ASRock Penryn1600SLI-110d
- 8GB @ 338MHZ
- Graphics Card(s)
- Palit GTX260 @ 707/1544/1200
- Sound Card
- [4.1 ] - Creative Labs XFI-GAMER
- Monitor(s) Displays
- SyncMaster T240 24" Dvi/HDMi
- Screen Resolution
- 1920x1200
- Hard Drives
- Hitachi 500GB
- PSU
- Winpower 750Watt
- Case
- Thermaltake Soprano
- Cooling
- Oem Cooler
- Keyboard
- HP Keyboard
- Mouse
- Optical Microsoft Mouse
- Internet Speed
- 3MBIT 350kb/s+
