Hey juaxor, I have the same headphones as you do and I suffer from a similar problem, the way I found of fixing this is to not use the usb to connect it to your pc, the usb is primarily for enabling the microphone but if your not too bothered about using the microphone then just connect it via a headphone jack from the wireless unit to a headphone slot on either your computer, speakers or monitor; just as if you were connecting an mp3 player to the wireless box but your connecting a computer instead if that makes sense then you can avoid any usb problems. :) Hope that helps
P.s if you really need to use the microphone all the time then unfortunately the only solution I have found so far is to use the usb and if the audio crashes then to disable and reenable the headphone and it works again, for me anyways.
