Sound Problems with WoW and other fullscreen games.
CoreyLowe
7:45 PM
Tornado alley =P
This problem for me is kindof hard to explain, When i open my World of Warcraft or Crysis with my sound on or even WMP running it distorts whatever sounds are playing horribly, Quite honestly it sounds like two trains colliding in your ears. Its disgusting, If anyone has had this problem or even knows how to fix this please help. P.S. I have updated my Realtek HD driver and still have this problem.
Windows 7 Ultimate x64AMD Athlon II x2 2.8MHz (2 Cores)6GB DDR2 1600 RAMHIS - ATI Radeon HD 4670 1GB DDR3
Custom Built PC
ASUS M4A785-M
6GB DDR2 1600 RAM
VIA HD Audio?
Acer LCD Monitor 17" + Polyview V17D 17"
1280 x 1024 x 60 hertz
Hitachi HDS721616PLA SCSI Disk Device 160GB Split into C: and D: Partitions
WDC WD32 00AAKS-00L9A SCSI Disk Device 320GB 16MB Cache
575W Logysys PSU
Sunbeam Transformer
6 Fans - 1 x 120mm, 3 x 80mm, 1 x 220mm, 1 x 90mm PCI Slot
Logitech G11 Gaming Keyboard
Logitech Trackball (Wired)
12MB/s Cox Communications
My bad for not putting my sound specs, Here they are. Dont know if it helps,
Name Unimodem Half-Duplex Audio Device
Manufacturer Microsoft
Status OK
PNP Device ID MODEMWAVE\0\{EBECA6B1-F6B7-45AF-9491-9E07DB6F6895}
Driver c:\windows\system32\drivers\modemcsa.sys (6.1.7100.0, 18.00 KB (18,432 bytes), 4/21/2009 10:53 PM)
Name Realtek High Definition Audio
Manufacturer Realtek
Status OK
PNP Device ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1019E619&REV_1000\4&4EDA02A&0&0001
Driver c:\windows\system32\drivers\rtkvhda.sys (6.0.1.5911, 2.62 MB (2,745,760 bytes), 8/15/2009 4:10 PM)
Custom Built PC
ASUS M4A785-M
6GB DDR2 1600 RAM
VIA HD Audio?
575W Logysys PSU
Sunbeam Transformer
Anyone???
Custom Built PC
ASUS M4A785-M
6GB DDR2 1600 RAM
VIA HD Audio?
575W Logysys PSU
Sunbeam Transformer
Anyone???
CL
Two things to check
1-device manager check your audio driver to make sure its installed and working.
2-Event viewer (type event viewer in search) to see if there are any errors realting to this problem.
Let us know what turns up
Ken
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
Okay im rather a novice when it comes to windows what exactly do i have to do with theese programs? BTW when i am not in theese programs my sound works fine.but i dont think its a bad installation seeing as it just so happens to do it in a few fullscreen apps
Custom Built PC
ASUS M4A785-M
6GB DDR2 1600 RAM
VIA HD Audio?
575W Logysys PSU
Sunbeam Transformer
