I have a front audio panel and a CMI 8738-6ch sound card.
The front audio does not work and has a wire coming directly from the back of it with this plug on the end of it...
There are 4 wires going into this plug.
On the sound card I have a 4 pin connector which, by trying with the computer turned off, I know fits this plug.
Despite them fitting together, this being the only wire coming from the front audio panel and plug being on the sound card we all know that naivety often makes 2+2 = 5 and so I was hoping some could offer guidance before I plug something in wrong.
Thanks in advance.
