My computer speakers do not work but headset works fine.
  1. Posts : 1
    64 Windows 7 Home Premium
    I get the following error. "The peripheral does not appear to be plugged in"
    I've updated the driver and it says the realtek device is working fine. Sound worked just fine on this computer but then stopped. I do not have external speakers. How can I plug in the speakers or fix the problem?
  2. Posts : 6
    Dual Booting Windows 7 Ultimate x64 & BackTrack 5
    I suggest you to check if your motherboard supports for your Windows audio drivers
    Before that if you change your audio driver ?
    http://www.facebook.com/100003250779989
