Solved How to keep System Sounds at 0 volume or mute?
gigagiggles
Pro User
12:20 AM
I find System Sounds does not stay at 0 volume or muted, with one exception: when volume mixer is open.
When I close the volume mixer and open a program that requires UAC, the chime is at "full" volume of selected device's volume setting.
As examples, Piriform's CCleaner and Revo's Uninstaller chime and reset the volume to "full" while Auslogics' Disk Defrag does not reset the volume but nevertheless chimes.
Is this a lost cause?
If you don't want any sounds, pick the "No Sounds" Sound Scheme. :)
Main - Windows 7 Pro SP1 64-Bit; 2nd - Window...Main - Core i7 2600K; 2nd - Core i7 920Main - 16GB Corsair Vengeance; 2nd - 12GB Cor...Main - XFX Radeon 6870 1GB; 2nd - XFX Radeon ...
Self
Main - Asus P8Z68-V Pro/Gen3; 2nd - Gigabyte GA-EX58-UDR3
Main - 16GB Corsair Vengeance; 2nd - 12GB Corsair Vengeance
Main - XFX Radeon 6870 1GB; 2nd - XFX Radeon 4870 1GB
Both: Onboard Realtek Azalia
Main - Hann 25" + I-INC 25" + Acer 23"; 2nd - Upgrading Soon
Main - 1920x1080 (All Three Monitors); 2nd - Upgrading Soon
Main - (1) Crucial M4 128GB (Boot)
Main - (1) Seagate 2TB 64MB Cache (Data)
Main - (1) Seagate 2TB 64MB Cache (Data Backup)
2nd - (1) Intel X25-M SSD 80GB (Boot)
2nd - (3) Seagate 1TB 32MB Cache (Data Backup)
2nd - (1) Seagate 320GB (Because)
Main - OCZ 600W Modular; 2nd - OCZ 600W
Main - Thermaltake Element G; 2nd - NZXT something or other
Main - Corsair H80; 2nd - Prolimatech Megahalems
Main - Razer Reclusa; 2nd - Old MS Keyboard
Main - Logitech MX Revolution; 2nd - Old MS Mouse
20Mbps Time-Warner Cable
I can't believe it was that simple! Thank you!
Glad you got it. :)
Self
