Windows 7: No sound at all, possible hardware issue
05 Apr 2012   #1
Jthw
Main=Ubuntu 12.04 x32 Other=Windows 7 Ultimate x64
Ok so, for a few days now whenever i plug in any audio device into the front of back plug ins on my computer, headphones or speakers no sound plays at all. Windows doesn't think anything is plugged in at all. I know both the headphones and speakers work because they have on multiple other devices. It might be a hardware issue with the computer because i move it around a lot more than i probably should. This is all the information i can think of right now if you need anything else please tell me.
05 Apr 2012   #2
fireberd
Please fill in the "My System Specs". Without that we can only guess or offer general suggestions.
The first general suggestion, since this is a recent problem is to use the System Restore and restore the PC back to a date when it did work (if that doesn't fix it, System Restore has an undo function to undo the restore). System Restore can be accessed from Start/Programs/Accessories/System Tools.
06 Apr 2012   #3
Jthw
system restore didnt work i am going to fill out my specs right now as best i can.
08 Apr 2012   #4
Jthw
and now my computer freezes at startup, should i add that on or start a new thread?
08 Apr 2012   #5
fireberd
Start the PC in Safe Mode - press F8 BEFORE Windows starts and then select Safe Mode (NO Networking).
You can run an "undo" on the System Restore, in case that caused the new problem.
09 Apr 2012   #6
Jthw
i have already tried to do safe mode, it freezes while loading, me and my friend are planning to just save the data on my hard drive, format it, and try a fresh install of windows.
11 Apr 2012   #7
Jthw
reinstalled windows along with all of the drivers for the motherboard and periphials. still nothing, its trying to output sound through the SPDIF port. thats the only thing that it is seeing as plugged in, and theres nothing plugged into it. out of ideas
12 Apr 2012   #8
fireberd
It sounds like a hardware problem on the motherboard if you have reinstalled everything and it still works that way. That motherboard is an ASUS motherboard, make sure you have installed the correct ASUS supplied sound drivers. Do not use drivers from other source or the generic Windows installed HD Audio Codec driver as they may not work or work correctly. Do you have a separate sound card you can install and use? Disabling the integrated audio in the BIOS and then using a separate sound card is one way around a suspected integrated (on the motherboard) sound chip problem. Or a separate sound card will at least prove whether it's hardware or you still have some driver or configuration error. If you don't have a separate sound card you can use, a cheap $20 sound card is better than the cost of a new motherboard, for testing.
Reoccurring low sound issue affecting two sound cards
I had this issue before, all of a sudden the sound coming from my computer gets really quiet even though everything is maxed out. Before, it seemed to have been triggered when I moved my computer from one room to another. I wasn't able to move it back right away but when I did it was still...
hardware issue or windows 7 issue
A couple months back, had issues with windows attributed to virus. I formatted C drive and did a clean install. Last week, windows was having issues with win explorer stopping , random crashes etc so i did another clean install Friday. Since then, I have had a few blue screens of death flash...
General Discussion
RealTek OnBoard Sound Issue - No Sound
Hello everyone, My audio has seem to quit on me. I updated to the newest drivers for my mobo (biostar A870U3) from their download page and now I get no sound whatsoever from my speakers. I have tried uninstalling all of the sound devices from the device manager and letting windows reinstall...
hardware issue, sound & frame shocking
Hello, So when I play games, the sound sometimes "hangs" (short fragment gets repeated) This also happens with the screen, and at first I would claim it on software (game to heavy, drivers, ect) but I recently reļnstalled my computer (full clean). So my windows is bright clean. The games them...
Hardware & Devices
Sound Blaster X-Fi Titanium Sound card issue
I have put the sound card into my computer and made sure that I've hooked up everything correctly, but I have ran into a problem with it. When I ran the download "Product Identification Module Update" from the Creative website, it's telling me that I don't have the right OS, and tells me to update...
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
