need help burning pictures to dvd
  1. Posts : 1
    windows 7 x 64
    i am trying to burn pictures onto dvd-r and would like individual folders of holidays etc, but when i try in windows dvd maker i do not get folders but one long stream of pictures amountin to hundreds on one long slide show and not individual folders.
  2. Posts : 3
    Windows 7 Ultimate 32bit
    You should use a burning software. I'd recommend Nero Burning Rom.
  3. Posts : 644
    Windows 7 home premium x64
    Using explorer before trying to burn a disc, put everything in the directory format you would like on your hard drive. Use a burner software and just select all the folders to create a disc.
    This is a free perfectly adequate burner, the interface is pretty much self explanatory. Any further probs, post again.
    good luck.
