HELP shift turns my volume down
Gary2975
6:43 AM
Whenever I press the shift key it turns my volume down Please help
windows 7 home premium 64 bit
Wow. That is quite the problem. If this is on a laptop (please update your system specs) then it could be that your shift key is a hotkey for volume down but if this is on a desktop running a legitimate Windows installation, virus-free then it's a bizarre problem.
I could recommend using a program such as SharpKeys to explore the issue. Sharpkeys is a GUI-based registry editor that enables you to change the functions of any key on your keyboard to that of another key. For example, on an older keyboard with no media controls I reconfigured my F11 and F12 keys to act as previous track and next track.
It takes a small amount of getting used to, but if you give yourself a few minutes to familiarise the layout and how the program works, then it's quite simple to use.
SharpKeys
Windows 7 Ultimate 64-bitAMD Phenom II X4 955 Black OC'ed 4.0GHz8GB Mushkin Enhanced Silverline (2x4GB) 1333XFX Radeon HD6870 1024MB GDDR5 OC'ed 945MHz; ...
Asus M5A88-V EVO
XFX Radeon HD6870 1024MB GDDR5 OC'ed 945MHz; 1151MHz
Soundblaster X-Fi Xtreme PCIe
32" Hannspree SE32LMNB
250GB Hitachi Deskstar (OS); 2TB Western Digital Elements
650W XFX XXX Edition 80PLUS Bronze Modular
Cougar 6GR1 Evolution
Corsair H60 p/p 120mm; Zalman VF3000A; x4 120mm; x1 140mm
Logitech G510
CM Storm Sentinel Advance Zero-G
Not fast enough :I
No matter what your specs, my PC is better.
