Windows 7: New PC's sound is way way too low
29 Apr 2012   #11
ignatzatsonic
Quote   Quote: Originally Posted by RealVen View Post
I've never had a sub woofer, and to be honest I'd be afraid that with the volume up the bass might take over and start vibrating etc. Anytime I hear someone plead for more base I get the image of the booming car driving down the road and I'm just not into that, I'd like a little clear base but not overpowering everything else.
That's probably a good instinct.
Subwoofers on PCs are often sold to game-players that just want to rattle walls without any intention of accurately reproducing music--just as subwoofers are sold to these jokers you refer to for car systems.
There are some pretty high quality amplified speakers for PCs, but not in your price range.
And they tend to be larger.
You just can't expect much from small speakers with a diameter of only a couple of inches.
So lower your expectations. They can actually sound pretty good if you don't have anything else to compare them to.
29 Apr 2012   #12
Trucidation
Personally I went for headphones - dollar for dollar they usually come off giving better sound imho. Since you prefer things loud and have ruled out headphones, well, just avoid the bargain bin speakers and you should be safe. Even the really cheap Altec Lansings are crap (I warned my friend but did he listen, nooo), despite their other stuff being pretty decent.
Edit:
Forgot to say, I wanted to emphasize ignatzatsonic's advice: listen to the prospective purchase if at all possible. Only you can decide between which of a store's several dozen speakers in the same price range sounds best for you. Good luck!
29 Apr 2012   #13
carwiz
Windows 7 Pro-x64
I got 2.1 speakers for a bedroom TV. Liked them so much, I bought the same setup for my main PC. I like them because they sound great, relatively cheap and has a remote volume control to which you can also connect headphones or Aux-in. The base response and volume are adjustable at the remote. And they BLAST! They'll rattle the walls if you want. I got both sets from Office Depot on sale. The Egg has them cheaper but after adding shipping, they're a tad higher.
Cyber Acoustics-3602 Speakers: Newegg.com - Cyber Acoustics CA-3602 30 Watts 2.1 3 Piece Flat Panel Design Subwoofer & Satellite Speaker System
30 Apr 2012   #14
fireberd
What you want is "cadillac" speakers on a "chevy" budget.
You want to play music loud but don't want to spend the $$ to get decent speakers. You generally get what you pay for, if you buy cheap you will generally get cheap speakers that won't have the fidelity or power and will distort. I've got a cheap 2.1 system that I bought on sale for $18 and I have a Phillips 2.1 set that I paid about $60 for at Sam's Club - no contest. The cheap system is now "collecting dust".
30 Apr 2012   #15
RealVen
Windows 7 Home Premium [64-bit]
So what are some good speakers for 2.0?
By "good", I mean the least expensive possible, but that you guys would still consider quality.
When ignatz says "high quality amplified speakers for PC's"
and fireberd says "cadillac"
what is the minimum price range we are talking?
30 Apr 2012   #16
ignatzatsonic
That's a confusing and contradictory definition.
One man's good is another man's unacceptable.
You are going around in circles. If you cannot audition the speakers, you MUST just take a leap of faith as you personally will have no idea what they sound like.
And you would be a fool to buy speakers because someone else says they are "quality", whatever that means.
If all you want is for someone to say that speaker X is "good", just go to Newegg reviews and look for the word "good" and buy the cheapest speaker in which you see that word. You would be a fool to do that, but it's your choice.
Different people have entirely different opinions about the "quality" of reproduced sound. Human memory for sound is terrible---people cannot even accurately identify a piano note struck 60 seconds ago from the note next to it on the keyboard.
But you already knew that.
You could look at more expensive speakers, say above $100, made by Swan or Klipsch, but what would be the point? You don't know if you will like them either without listening. You may think they don't sound any better than a $30 pair. Which is fine and which would make the extra expense wasted.
Toss in the state of your own hearing (frequency response) and you have even more reason not to listen to anyone else's opinion.
30 Apr 2012   #17
RealVen
Alright, I will just have to make a decision then. Thanks for all the help!
30 Apr 2012   #18
RealVen
Do you guys have any opinion on the Creative Labs T10 speakers @ $45?
Compared to say the Logitech X-140s at $30?
Again I don't want the walls to vibrate, just looking for clear sound, will not spend more than that though.
Thanks again.
add:
I also found some Logitech Z320 on sale for $39.99, maybe they are good value?
01 May 2012   #19
fireberd
Without actually hearing them, I can't make an "educated" assessment.
Any of those look good, but hearing is a different story.
01 May 2012   #20
carwiz
Windows 7 Pro-x64
That's the problem. What sounds good to one person may sound like a rattle can to another. Review the specs and choose a set that has a response in the range of 100-150Hz to about 12,000-15,000Hz. These should provide a good range of sound at a lower price. The problem with 2.0 is that you'll need "full range" speakers to get the lower end and these are generally higher priced. That's where 2.1 speakers shine. The internal amp splits off the low frequencies and sends them to the woofer. Mid and high range frequencies get sent to lower cost speakers. I paid $39 +tax for mine. I've only heard "better" from $600+ speakers. But, I have to admit, I'm no audiophile.
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
