Windows 7: how to fix audio problem in WIN 7
29 Apr 2012   #1
anna92
Windows 7 Ultimate 32-bit
im having some difficulties in fixing my audio device. i googled n even went to youtube to learn to fix it but nothing changed. i did almost everything stated.i tried to update my driver but it said "device cannot start (code 10). help please.
im using acer aspire 4520.
how to fix audio problem in WIN 7-capture-20120429-155602l.png   how to fix audio problem in WIN 7-capture-20120429-155705k.png
29 Apr 2012   #2
fireberd
Code 10 is usually a driver error. Are you using the Acer supplied sound driver (or trying to install it)? If not that is the first step, many times non-vendor sound drivers will not work or not work correctly.
I see you also have what looks like HDMI audio from the ATI Video Card, that also has the Code 10. There can also be some type of conflict that is causing the Code 10. Disable the ATI audio in the Device Manager and see if that will allow you to install the Acer sound driver.
29 Apr 2012   #3
anna92
what's the difference between using acer supplied sound driver and installing it? sorry, im kinda new to this. i disabled ATI and also tried reinstall realtek before and didnt work.
29 Apr 2012   #4
fireberd
Many times, PC Vendors will have a custom OEM motherboard and chipset implementation which requires the vendor's drivers for a device to work properly. The sound chip vendor, such as Realtek has generic drivers and if the PC vendor does not do anything special then the generic sound chip vendor's drivers will work OK. I've seen statements on RealTek and IDT sites about this exact subject.
I do a lot of support on the Dell users forum and we see this specific problem frequently on there. Dell drivers must be used for all functions to work. In fact the generic chip vendor's drivers won't even install on some systems.
This may not be the problem with your specific situation, but the first step is to install the PC vendor's sound drivers.
01 May 2012   #5
anna92
oh, okay. thanks what should i do after installing the driver?
realtek high definition audio and high definition audio device problem
Hi everyone, I would be very grateful for some help please! My laptop recently installed a BIOS update - I don't know what this was but since it happened I have been having sound problems with my laptop. After the update I had no sound. I read around and found how to get the sound back on - I...
"Scan for Hardware Changes" fixes audio problem, but problem returns
Hi all, Issue: The sound on my internal laptop speakers does not work when I try to play audio. Solution: However, if I go into "Device Manager" and click "Scan for Hardware Changes" on the "Sounds, video and game controllers" section, my sound returns instantly. The moment I click "Scan..."...
Audio problem, Audio device is disabled.
I turned on my laptop the other day and no audio would play from anything, like youtube videos or itunes. I checked my volume control nothing was muted. When I opened itunes I got a message saying "itunes has detected a problem with your audio configuration. Audio/video playback may not operate...
restart problem BSOD glitchy audio win7 ultimate w/ m audio 1010lt sou
m audio 1010lt sound card not sure why..usually when I shut down it restarts automatically..recently i was watching a movie and it restarted out of no where..any help appreciated.... windows ultimate 7 amd 6000 3.0 ghz processor 4 gb ram I did do some searching i do have m audio 1010lt and...
BSOD Help and Support
Audio problem
Hello all, my audio was working fine for a year, but a few days ago there was no sound, so I restarted my computer and the sound worked for 30 mins or so then went out. I checked to see my drivers were up to date and they were. So then I uninstalled the driver and tried to reinstall one from HP...
