Windows 7: Realtek onboard sound card with 5.1 surround speaker fill problem
23 Dec 2013   #31
zach99zulu
Here is the fix
Intro:
I spent several hours over the last couple days trying to figure out why there is no sound coming from the REAR speakers when playing 2.1 sources and such (streaming videos or music from online). 5.1 sound works in video games and DVD/Bluray, etc. There was no SPEAKER FILL option in the most recent REALTEK drivers.
Quick rundown of my problem:
5.1 audio only worked for 5.1 output sources, not for everything.
Interesting details:
CONTROL PANEL > HARDWARE AND SOUND > SOUND, click Speakers (typical output source.... where the sound comes from), then the Configure button.. By default, it's set to Stereo (I just built a new computer, so this is where I was sitting). Set it to 5.1 Surround and it WORKS.... for only one source (I would steam a channel on DI.fm and if I reopened that stream, it would revert back). If I reopen anything or change a sound setting, it'll completely stop or it'll revert back to stereo sound. VERY clear difference, as with stereo, the volume out the front and center speakers is way louder than on 5.1, even on the same volume setting (I was using 50%).
I would change it from 5.1, open a source, change it to Stereo, open a source. There was a clear difference, and as said before though, it only works for ONE source. Keep in mind, Windows has an audio driver that has the SPEAKER FILL option, but as you're all probably aware, it's garbage. VERY quiet!
SOLUTION:
CONTROL PANEL > HARDWARE AND SOUND > SOUND, click Speakers, then the Properties button, click the Enhancements tab (by default, Immediate mode is selected.... I left it checked, default position). Scroll down to the bottom of the list and check DTS Connect. Apply.
You can even use the Room Correction enhancement to further produce a more desired volume from your speakers based on your configuration!
Fixed the issue. I can now restart my computer, play multiple sources, etc, without having to change anything in the sound options ever again!
MOTHERBOARD: Asus Maximus VI Hero w/onboard Realtek HD audio.
23 Dec 2013   #32
Night Hawk
W7 Ultimate x64/W10 Pro x64 dual boot main build-remote pc W10 Pro x64 Insider Preview/W7 Pro x64
Hello zach99zulu Welcome to the Seven Forums!
Due to the age of this thread I would recommend starting a new one rather then expecting help here especially since you seem to be having a more involved problem. That will a bit more room without stepping the help offered to the OP here. You'll find you will get more help faster as well.
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Alternative to speaker fill: Realtek 3D SoundBack
Realtek 3D SoundBack 0.1 Beta I upgraded from Xp to WIN&, which is great but i've been having issues with the notorious 5.1 issue with the Realtek on board sound. I've been able to get 5.1 sounds, but when watching videos with VLC i would be limited to 2.1. sound. This allows you to...
RealTek OnBoard Sound Issue - No Sound
Hello everyone, My audio has seem to quit on me. I updated to the newest drivers for my mobo (biostar A870U3) from their download page and now I get no sound whatsoever from my speakers. I have tried uninstalling all of the sound devices from the device manager and letting windows reinstall...
Realtek onboard sound card: Static/Crackling noises
Hey, I recent put together this new rig. I'm using the onboard sound card for my Gigabyte GA-X58A-UD3R Rev 2.0 mobo. The sound chipset is Realtek ALC889. I've updated the latest drivers, but there is crackling/static noise when I play music. Currently I mainly use a 2.1 speaker system. But...
Surround Sound + Realtek
OK So! Ive tried EVERYTHING even bought a new set of speakers thought the others were broken. I am running windows 7 ultimate and i have tried every realtek driver known to man. And I still can't get my surround sound to work I haven't re-assigned the jacks cause i am not to sure how to do that...
realtek ac97, onboard sound
hi guys, new here and is my first post, so i have a dell comp, with a realtek ac97 onboard sound card, now running windows 7, but have no sound coming from pc. have uninstalled sound drivers and reinstalled new ones, have done this 3 times now, but still no sound, finally i have sound going to...
