Windows 7: Low audio quality on bluetooth headset
22 May 2012   #1
Windows 7 Home Premium 64-bit
I have a Nokia BH-214 receiver. I tried pairing it with my Windows 7 PC and despite a lot of trouble (system couldn't find drivers for the device) I followed the instructions on the following page and finally made it work:
Installing Bluetooth Headset on Windows Vista / Windows Server 2008 - Komeil Bahmanpour
The problem is that the audio is terrible. I know the device is capable of great audio as I've connected it to my iPhone and Nokia phone all of which had great audio. I went into the device properties under sound settings and under the Advance tab it says that the "Default format" was "1 channel, 16 bit, 8000 hz". I'm no guru, but that sounds really bad, no pun intended. The problem is, the drop menu is grey, I can't change the quality to anything better.
I've tried everything I can think of and I can't change it. Does anyone have any advice?
Thanks in advanced,
Raz
Similar help and support threads for2: Low audio quality on bluetooth headset
Bluetooth headset connected but no audio Sound & Audio
Solved Bluetooth headset + bluetooth Dongle help Hardware & Devices
Quality of Smart phone audio vs standard LAPTOP PC audio Sound & Audio
Bluetooth headset audio goes silent but resumes delayed audio Sound & Audio
Add bluetooth headset Drivers
Quality bluetooth mouse? Hardware & Devices
Bluetooth Headset Help... Sound & Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
