Realtek HD Audio Drivers - Constantly detecting/undetecting front jack
Darats
10:25 PM
Hello all,
I rercently came with the following problem without any reason:
I have a realtek audio chipset with my mother board.
Since some time, the HD audio drivers keeps on detecting/undetecting a device plugged in my front jack (resulting is sound cutoff, which is more than annoying). But, there is nothing plugged.
If I plug something then, the detection works right.
I'm wondering if it is a software problem, or if there is something wrong with my motherboard or my front jack connector (some kind of shortcut or whatever).
If someone as a solution I would really appreciate.
Thanks a lot in advance !
I cannot uncheck the "reload" option in the realtek driver because I need to have this detection working right.
Sounds like a loose or defective jack. No software will "fix" broken hardware. When nothing is in the jack, it's grounded and the chipset ignores or turns off the jack. When you plug something into it, the open ground signals the chipset to detect a device and notify Windows of it's presents. Windows (driver) will then allow you task the jack as necessary.
You don't give any info on your system but some manufactures have spare parts available. Most front panel assemblies are replaceable. Also make sure the front panel connections aren't loose at the motherboard. Be sure to completely power-down the PC and un-plug the power cord before checking wires inside.
Windows 7 Pro-x64i7-2600 3.4GHz - 3.8GHz Turbo8Gb - 2x4GB, Muskin 991770 PC3-1333Integrated Intel HD 2000
Built 2/11/2011
Windows 7 Pro-x64
Intel DH67BL-B3
Integrated Intel 10.1 HD, RealTek ALC892
Asus LCD VH222H, Haier HL24XSL2a
1920x1080, 1920x1080
Crucial SSD C300-128Gb,
Western Digital WD5002AALX - 500Gb,
Western Digital WD7501AALS - 750Gb
Seasonic 650W 80+ Gold Modular
Rosewill Defender
Stock CPU, Four 120mm case fans, PCH fan added
Logitech EX100 Y-RBH94 Wireless
Logitech EX100 M-RCE95 Wireless
3.0/1.5 Mbs
Microsoft Internet Explorer 11
Antec Veris Premier-Multimedia IR Station,
Cyber Accoustics-3602 Speakers,
AFT XM-5U Card Reader,
Hauppauge TV-HVR-2250,
Sony LX300 USB Turntable
Thanks for your reply.
So I did several checks:
  • If I plug nothing it detects/undetects
  • If I plug something in either micro in or speakers out (green or pink) it works nicely.
  • Then, I've unplugged the HD Audio cable from my motherboard: it work nicely (it stops to detects/undetects)
  • Then, if I plug this cable on the motherboard but disconnect it on the front jack side, it starts to detect/undetect.
I don't know which kind of diagnostic I can made from these tests (maybe a bad cable)...
FYI, I have a Fractal Design Define R3 - Black Pearl and a Gigabyte GA-X58-USB3 for the Motherboard.
It could be a bad cable connector or loose pin on the motherboard. Check the wires carefully too.
Built 2/11/2011
Windows 7 Pro-x64
Intel DH67BL-B3
Rosewill Defender
3.0/1.5 Mbs
So, the pins seems to be OK. They are not moving.
It's hard to say if the cable is right. At first sight, all the wires seems to be connected to the connector (they are not loose).
Besides, I've noticed that if I plug the AC97 part of the cable instead of the HD Audio one, the problem is gone.
I hope it's a cable problem and not a motherboard one. Am I right?
It sounds like a cable or cable connector problem.
Built 2/11/2011
Windows 7 Pro-x64
Intel DH67BL-B3
Rosewill Defender
3.0/1.5 Mbs
I will try to see if I can get a cable replacement from Fractal Design.
Simple solution
Open Real Teck manager
click speakers
Right click green button (that is my connection yours may be different)
Choose "connector retasking"
at the bottom of the page you will see "enable auto popup dialog"
Disable it and you are set to go.
The newer version of Realtek manager is different.
But is basically the same. Look for - "enable auto popup dialog" and disable it!!
:mad: those popups bug me
Win 7 home premium 64 bitIntel Core i7 i7-2600KKingston Value RAM 8GB DDR3Asus ENGTX560 TI
custom
ASUS P8Z68-V PRO
Asus ENGTX560 TI
motherboard HD Realtek
Samsung 275t
OCZ Technology Vertex 3
Antec CP-850 ATX12V
Antec DF-85
Corsair A50 Cooling Fan
thx Mr.TF6 its a working i feel happy thx so much
windows profssional x32i34GBNOT USE
costom bilt
i3
DH67BL
4GB
NOT USE
150GB
AVG 2014
CROME
