No Audio Device Detected
  1. Posts : 8,383
    I have an old HP Pavilion dv9608nr and recently from time to time my Conexant audio device isn't detected by Windows & It doesn't even appear in Device Manager.
    Things I've tried:
    Scanning for hardware changes - No change
    Trying to reinstalling the driver - No device detected
    Using a Linux Distro Live CD - Works perfectly
    Restarting the Audio Service - No change
    SFC Scan - No change.
    System Restore - No change
    I'm out of ideas. Any suggestions other than reinstalling Windows?
  2. Posts : 190
    It sounds like either failing hardware or an incompatible driver. After looking at the HP support site I can see that there are vista drivers for this model but nothing for 7. It may be time for an upgrade...
    I had an HP recently where the USB ports were intermittently malfunctioning and then completely failed altogether. Turned out to be a failing motherboard, seems to me that your hardware is most likely failing
  3. Posts : 8,383
    Yep, HP doesn't offer any Drivers for Windows 7 but those which were previously installed were from Windows Update and were released in 2011. I've been having that bad feeling that the hardware could indeed be failing, seems that a reinstall/repair install might be my last option here.
  4. Posts : 190
    I'm inclined to lean toward a hardware failure because you've said that the device even disappears from device manager when it isn't working. Normally when hardware isn't working it will still show up, but with a warning indicator on its icon.
  5. Posts : 8,383
    Yeah, this makes sense, I guess this case is solved. Thanks for your input. :)
  6. Posts : 190
    No problem, it's unfortunate that the hardware is at fault here. Hopefully you have another machine to fall back on
