My PC has no sound after sleep mode.
Croywiggin
12:49 PM
Upon waking my PC from sleep mode the sound will not work.
Any help will be greatly appreciated.
Windows 7 64
Windows 7 64
click start menu. go into the run command.
type "services.msc" without the quotes
scroll down to windows audio. right click and highlight properties.
go to the recover tab and click the panels always have it set to restart the service.
that should solve your audio prblem
windows 7 x64 pro sp1intel i5 2540m8 gig ddr3 12800intel hd 3000
asus k53e bbr23 laptop
intel i5 2540m
asus
8 gig ddr3 12800
intel hd 3000
realtek hd audio
1366*768 hd
(1) ST3250312AS ATA Device (2) TOSHIBA External USB 3.0 USB Device
lenovo usb mouse
20Mbps/1Mbps
Some times when you resume from the sleep mode. This a common problem. Goto the audio manager settings reset all your audio settings and restart your computer. This will solve your problem.
no sound after resuming from sleep mode
I'm running Windows 7 Ultimate and I ran into the same loss of sound after a resume
from sleep mode. Drove me crazy for quite a while. :cry:
The quick fix was to right-click on the speaker icon in the system tray, select the speaker on the menu, disable the speaker then re-enable it. Sound works again but this was a pain in the butt doing it on a regular basis.
Finally got it fixed, though. Turned out to be Creative's SoundMax software that was
preventing the sound driver from re-initializing on resume.
Uninstalled SoundMax, rebooted and the problem was gone. Works fine now.
Not sure if this will work for you but it's worth checking what you've installed just
before this problem manifested itself on your computer.
Windows 7 Ultimate x643.2 ghz Intel i7 quad core12 gigabytes DDR3ATI Radeon 5700
home built
Asus P6T WS Pro
12 gigabytes DDR3
ATI Radeon 5700
Creative SB X-fi
HP 2129m flat screen
one terabyte Western Digital
1000 watt Thermaltake
large server case
four fans
w1dpc, I registered just to say thank you :) . After 11 months my problem is solved.
Then mark his reply as the solution to the OP so that the whole thread is not considered solved :)
Win 7 x64
HP
Win 7 x64
