2 audio outputs? Help with sound card
  1. Posts : 8
    Windows 7 Pro 64bit
    Hey, I know this is a topic that must have came up so many times, but after trying several methods on Google, I've had no luck.
    So yeh, I'm wanting to have 2 separate audio outputs. So I first had an output coming from the motherboard. I then added a sound card as I beleived this would allow me a second audio output. Now however, I can only get sound from the sound card. To test I have speakers plugged into the sound card & headphones into the motherboard.
    Some (possibly) useful system info:
    Windows 7 Pro (64 bit)
    ASRock 880G Extreme3 (Socket AM3) DDR3 PCI-Express Motherboard
    Creative Soundblaster X-Fi Fatal1ty Xtreme Gamer Sound Card
    Please tell me if any more info is required, thanks!
  2. Posts : 1,851
    Windows 7 pro
    As far as I know windows can only use one device at a time so the only thing that you can do would be to change the default device when you want to switch.
  3. Posts : 8,135
    townsbg is correct. You can only have one default audio playback device. e.g. either the added sound card or the Integrated audio.
  4. Posts : 21
    Windows 7 / Ubuntu
    I'm having the same problem atm, all the 'solutions' I've tried have been in vain ._.
    I'm starting to hate windows 7 for this really, this is so stupid that they don't have something like this, and it's even hard to set it up.
    L.E: Follow this, it's just great:) http://theitbros.com/hotkey-to-switch-audio-devices though you won't be able to listen to both simultaneously, it's still better than doing 5 clicks every time you want to switch.
  5. Posts : 13
    I have been using two cards for quite a long time and had no problems - just the hassle of choosing the sound output device for some apps. The main card was an Audigy and the secondary was an onboard (quite good).
