2 audio outputs? Help with sound card
DivAnder
10:26 PM
Hey, I know this is a topic that must have came up so many times, but after trying several methods on Google, I've had no luck.
So yeh, I'm wanting to have 2 separate audio outputs. So I first had an output coming from the motherboard. I then added a sound card as I beleived this would allow me a second audio output. Now however, I can only get sound from the sound card. To test I have speakers plugged into the sound card & headphones into the motherboard.
Some (possibly) useful system info:
Windows 7 Pro (64 bit)
ASRock 880G Extreme3 (Socket AM3) DDR3 PCI-Express Motherboard
Creative Soundblaster X-Fi Fatal1ty Xtreme Gamer Sound Card
Please tell me if any more info is required, thanks!
Windows 7 Pro 64bitAMD Phenom II 955 (Quad core)12GB DDR3
Windows 7 Pro 64bit
12GB DDR3
Samsung 1TB SATA3 HDD
Stock CPU fan + 5 Case fans
Logitech Wireless MK250
Logitech Wireless M505
<1Mbps
As far as I know windows can only use one device at a time so the only thing that you can do would be to change the default device when you want to switch.
    Windows 7 pro/Windows 10 ProIntel i7 860 Quad core 2.8 ghz8 gbATI Radeon HD 5770 1 gb ram
    HP Pavillion Elite HPE-250f
    8 gb
    Alienware 25 AW2521HF & Viewsonic
    1920 x1080 & 1680x1050
    WD blue 1 tb & 500 gb.
    FF of course.
    https://www.bestbuy.com/site/hp-pavilion-elite-desktop-intel-core-i7-processor-8gb-memory-1tb-hard-drive/9921493.p?skuId=9921493
    Windows 2012 R2 Data center/Linux Minti3 9100 3.6GHz, 8M cache, 4C/4T8GB 2666MT/s DDR4 ECC UDIMM
    Dell Poweredge T140
    Viewsonic
    1 TB & 750 GB
    https://www.dell.com/en-us/work/shop/productdetailstxn/poweredge-t140?~ck=bt
townsbg is correct. You can only have one default audio playback device. e.g. either the added sound card or the Integrated audio.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I'm having the same problem atm, all the 'solutions' I've tried have been in vain ._.
I'm starting to hate windows 7 for this really, this is so stupid that they don't have something like this, and it's even hard to set it up.
L.E: Follow this, it's just great:) http://theitbros.com/hotkey-to-switch-audio-devices though you won't be able to listen to both simultaneously, it's still better than doing 5 clicks every time you want to switch.
Windows 7 / UbuntuAMD 2.90GHz dual 5700+4.00 GBs of RAMATI HD 4850
Windows 7 / Ubuntu
A3A
4.00 GBs of RAM
ATI HD 4850
LG FLATRON W2241S 21 inches
512 GBs
I have been using two cards for quite a long time and had no problems - just the hassle of choosing the sound output device for some apps. The main card was an Audigy and the secondary was an onboard (quite good).
Microsoft
