Windows 7: Case's audio panel microphone doesn't work
17 Jun 2012   #1
Windows 7 Ultimate 64-bit
I have recently custom built a PC using an ASUS M5A78L-M/USB3 motherboard in a CiT 2206 MIDI Case.
I have downloaded VIA drivers from the motherboard website I linked above, but uninstalled the program that came with it (It didn't manage audio very well and prevented my speakers from working :/ ; also my front panel microphone didn't work before uninstalling this program either)
Anyway, my problem is that when I put a microphone into the microphone jack on my case (front of case) It doesn't work and windows doesn't detect any recording hardware. When I plug a microphone into the motherboard, It works straight away without a problem. I really need the front panel to work for Skype and other audio recording needs as my cable will not reach around the back of my case.
Any suggestions? Thanks in advance
17 Jun 2012   #2
Win7 Ultimate X64
Are you sure the jacks are connected properly, double check all connections
17 Jun 2012   #3
Thanks for the quick response It appears to be all the way in. it won't go in any further and looks the same as the headphones plug (which works by the way )
If you mean the internal connection I'll check but I think it is in properly
17 Jun 2012   #4
Ah one second, just noticed that windows doesn't say "Not plugged in" it says "Currently unavailable"
17 Jun 2012   #5
I'll try the VIA website for up to date drivers
EDIT:
Got the drivers, now I'm going to reboot and see if they work
17 Jun 2012   #6
Fixed it
In the program that came with the driver (HD VDeck(which has been causing the problem all along)) there is a setting called "enable front panel jack detection" which must override windows' default "jack detection". with that setting disabled all is working fine no thanks to HD VDeck. Going to uninstall the program now and see if it still works
Thanks for your suggestions and help Pauly.
+rep
-tylergard702
17 Jun 2012   #7
Win7 Ultimate X64
Glad you got it sorted, thanks for sharing your fix
Similar help and support threads for2: Case's audio panel microphone doesn't work
Front audio Panel doesn't work (ASUS P7P55D motherboard) Sound & Audio
Microphone doesn't work Sound & Audio
Laptop microphone doesn't work Sound & Audio
Microphone doesn't work well Drivers
My microphone doesn't work Sound & Audio
Front Panel - Microphone Do not work,, Sound & Audio
My frontal audio panel doesn't work. Drivers? Drivers
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
