Creative SB-XFI Titanium - problem
  1. Posts : 79
    W 7
    Hi guys thanks in advanced Umm my problem is i keep deleting/uninstalling my Soundcard and its programs but when i reinstall i seem to be having this same problem saying The audio device is not supported by this application will now exit
    Sound card - Creative SB-XFI Titanium Champion series
  2. Posts : 6,879
    Win 7 Ultimate x64
    Are you installing the latest from Creative or something like this,
    SB X-Fi Series Support Pack 2.0 (05/15/2009) - Creative Labs
    or are you installing what came on the disk with the card?
  3. Posts : 79
    W 7
    Na i got the Creative auto update software program thingy from the website and i use that to update my drivers and software. Although i will give that support thingy a try thanks for that.
  4. Posts : 79
    W 7
    Nope the support pack didn't do anything still get that same stupid problem occuring
  5. ECH
    Win7
    MS has offered an update for that and I've not experienced any problems using it. Did you check with them?
  6. Posts : 501
    Windows 7 Ultimate X64
    Thanx to stormy13 for the link ...rep given !!
    x64 X-Fi drivers installed flawlessly ....7.1 speakers never sounded so alive now wow!!
  7. Posts : 2
    windows 7
    hi i have the same problem with mushroom also my speakers appear unplugged and i don't have any sound i tried the support pack 2.0 but nothing happened please help me
    the only option that appear active is the spdf but not the speakers
  8. Posts : 4,573
    One thread per problem, please.
    problem soundblaster xfi titanium
