Windows 7: problem default device
05 Sep 2009   #1
Mason69
Vista
I'm having this weird problem, only my speakers works or my headphones works, they never work together and when I want to change I have to select which one I want as default device in the control panel. The thing is: I don't want to do this everytime I use my headphones, so can anyone help me??
Im using the beta version of 7 in a separated partition and vista in another and i didn't have this problem in vista.
And sorry for the bad english.
14 Sep 2009   #2
iseeuu
Quote   Quote: Originally Posted by Mason69 View Post
Hi Mason69, and welcome to Windows Seven Forums!
This thread has a link where Microsoft says there are 26,000 custom audio drivers, so not all of these drivers have been added to Windows 7 yet.
A bit dated but worth reading
Some have been able to get drivers to work for them, and we would like to help you there but you have not provided enough info to do that. We would need to know what chipset your computer is using for audio. A start would be to know which computer you are using, laptop, desktop, brand name and id, home built, sound card, etc., etc., ... If you would like to provide more info, we will try to find you a driver that will work.
Cheers!
Robert
14 Sep 2009   #3
TGSoldier
I don't think you'll be able to switch the default device automatically.. I know you can do it per program.. ( Well at least in winamp, I know I can set which device i want to emit the sound )
14 Sep 2009   #4
Antman
My sound card has an option to automatically detect headphones. Driver specific I guess.
Unknown device in device manager after Bios default settings are
applied. Sorry that last word didn't get in the subject line. So: http://i.imgur.com/QoSy2wX.png These two values are: USB\VID_0CF3&PID_3000&REV_0200 USB\VID_0CF3&PID_3000
Drivers
audio device isn't set as default, can't make it default
Hi all, Windows 7 Home Premium x64 on HP-DM1-4050us laptop, disabled a couple of unneeded services, now headphones not working, no idea which service caused this but I didn't touch either of the two required audio services (Windows Audio, Windows Audio Endpoint Builder). Audio now plays fine...
Default Audio Device Problem
Hi guys, Windows 7 is having trouble saving my default audio device. Every time I assign it, hit OK, and restart it changes from what I set it to. So every restart I have no sound and I have to manually change the playback defaults and it works fine until I restart again. This what it looks...
Problem selecting Default Audio Device
I'm having a problem with my sound devices. I plug my headphones in, my headphones work fine in other devices, but my computer still runs the sound through the inbuilt speakers instead of through the headphones. The only program I can run through the headphones is WIndows Media Player because I...
How do I get Stereo mix working when usb device is default device?
Hi guys, so I did some tweaking around in Sounds and Realtek HD Audio Manager, and I finally got stereo mix working. There's only one catch. It only picks it up if my default device is Reaktek HD Speakers. I tried setting my USB headset as the default device, since I never use my monitor's built in...
Default Playback Device?
Im using Win 7 x64 and in the notification area, it shows sound. But nothing comes out of speakers. When I click on the other playback device, it works! I set it to default, turn off computer, and settings have changed!! Any help?
