#31
My first thought was a weak battery (still could be), but when you mentioned stopping the hibernation, what that did was stop the thrashing/preparation the HDD had to do in order to prepare itself for hibernation, and that removed the slowness you noticed.
I prefer hybrid mode, but that might not be available on your d7 because it is a notebook.
You might be able to do it here, see the Tip box at the beginning: Hibernate - Enable or Disable
On your 1st edit:
Continue with the other scans if you didn't install the keygen it has got to be harmful, you did remove it didn't you?
Don't despair, MSE will take a long time on its first full scan.
2nd edit:
Ah...The joys of living abroad....Glad to hear System restore is working.
