Windows 7: sound is low when listening on my earphones
23 Jun 2012   #1
CityLady
windows 7 64bit Enterprise
Hi there I have noticed recently that when I use my earphones which Ii plug directly into my speakers, if I watch a movie the music is very high but voices very low and I have to turn the volume up full to even hear them. This happens on VLC and WMP but if I watch something using a web browser, it's ok.
I do not know how to rectify this as I have disabled and enabled sound drivers
I really am stumped by this.
thanks in advance
CityLady
23 Jun 2012   #2
fireberd
This would suggest a configuration problem with the movies. Some movies have configuration options for the audio and that is a place to start. Also, if you are using any sound enhancements that is another potential issue.
Headphones/earphones don't work
Hi there http://www.techsupportforum.com/images/smilies/wave.gif I'm new here, and being a girl (J/K), I don't quite get along with my computer http://www.techsupportforum.com/images/smilies/1-shy.gif Here's my problem: My HP Compaq Presario CQ60 - 215EP had the Windows Vista as the...
Laptop freezes and makes buzzy sound when listening to music.
Hello guys, I've had the freezing problem for months and so far no solution. My laptop runs fine when I play games, or browse, as long as i don't watch videos or listen to music, it doesn't mind if online or from my drive. Tried different software but no luck. I would think it's hardware, but i...
BSOD Help and Support
Sound only coming out of one earphone, not the earphones.
Hi all,for So I have been having a fair amount of problems with my speakers since I acquired the laptop in October; the quality and volume are both terrible, but after reinstalling drivers and speaking to members on this board, and we deduced that the laptop speakers were just shocking. ...
Audio too loud on earphones
I upgraded to windows 7 but every time I use my earphones I need to keep my volume at level 1. If I go even higher then level 10 the audio is really loud. I'm using Realtek HD.
How do I get sounds to be played back through my earphones?
I would like to know how I can get all of the sounds on my HP Compaq laptop to be played back through my earphones and not the built-in speakers. Windows Media Player for instance works fine when I start it up after plugging in the earphones, but apps like Mozilla Fire Fox uses the HP built-in...
Extremely low sound from earphones...Help!
I have a XFX nForce 680i LT SLI board with onboard Hi-Def. Using Win7 Ultimate 32bit. I use my Blackberry earphones plugged into the back panel green jack. Never had any problems with this setup until about a week back. A week ago, without ANY apparent reason (no new programs/drivers...
