Solved Front Panel audio not working correctly
MadSupra354
Supra
Pro User
3:28 PM
On my chair, in my room
When I plug-in my headphones into the front panel jack, the audio will only emit from the left speaker. I haven't tried re-seating my sound card, don't know if it's necessary. Is there anything other than analog output (Xonar DX Audio Center) that I have to change in order for it to work correctly?
I'm using UNi Xonar drivers. They are a fixed version of the Asus drivers.
10 Home x64Intel Core i5 4670KCorsair XMS3 8GB DDr3 1600MHzSapphire NITRO Radeon R9 Fury
10 Home x64
Intel Core i5 4670K
Gigabyte GA-Z87-D3HP
Asus Xonar DX
Acer H236HLbmjd
Force GS 128GB - Seagate 320GB - WD Caviar Black 1TB - WD Caviar Blue 500GB
EVGA SuperNOVA 650 P2
Silverstone Raven 3 RV03B-W
Topre Realforce 104UG-HiPro
Mionix Naos 7000
76/4 On a good day
SmartScreen
Internet Explorer 11
I am fairly ignorant about Sound cards, but I can direct you to a review about this card:
TinyURL.com - shorten that long URL into a tiny URL
When you say "...the audio will only emit from the left speaker." do you mean that you are running this piece of kit as 2.1 channel, with sereo and a woofer, or more than 2 speakers? I ask because, although I am not 'into' gaming and PC sound issues, I did know quite a bit about Hi Fi sound once.
The Review states that the card uses 2 chips to provide sound to each set of channels, instead of the 1 chip as used by Creative. If, as you say, your card may not be seated correctly, this could cause your problem. Won't harm to check, if you are careful. My thinking, which may be wrong, is that one chip may serve right channels whilst the other serves left channels.
Also, note this from the Review: "... the Xonar DX still requires a power connector..." and this: " it’s a floppy connector and not a Molex..."
I wonder if you made the right connections? Not doubting your knowledge or technique at all, but I have missed stuff by simply not reading the instructions carefully enough. Or not at all, sometimes.
That's about all I can help you with, hope you sort it and if so please post back with results, I am intrigued now.
Windows 7/64 HPremium.AMD FX-6300.Corsair (2x4) GB DDR3 CMXGX3M2A1337CL9.NVidia/Gigabyte GT730 (2GB) GDDR5.
bertison
AMD FX-6300.
Asus M5A78L-M LE/USB3.
Onboard.
Iiyama PLE2407HDS.
1920 x 1280
Desktop: 1TB. WD10EZEX-00BN5A0.
Zyxel nsa310 NAS: 2TB Seagate Barracuda 7200.14.
Cache Drive: Sandisk SDSSDRC032G.
Laptop Lenovo B50/80 128 GB SSD.
Corsair 750M.
Coolermaster N300.
FRONT: (2X) 140mm. TOP: (1x) 120mm. REAR: (1x) 120mm.
Logitech K290
Trust Optical Wired
15 Mb Down, 0.55 Up.
Kaspersky Total Security 2017, Hitman Pro.
Firefox.
NETWORK:
Sky "Q box" and router.
Desktop & NAS - 30 Metres Cat6 Ethernet wired, via TP-Link 4-port switch.
Lenovo B50/80 Laptop, 2x Wileyfox phones, Lenovo TAB3-8 tablet - all wireless.
Grandchildren, their parents and friends as bandwidth 'parasites' at various times!
In the software, there are 2 front panel options: FP Headphone and FP 2 Speakers.
I have it on FP Headphone. Right now, I'm using Hi-Fi headphones (that I literally got ~20 minutes ago from Amazon). I have 5.1 headphones connected directly into the rear of the sound card for when I want to play games, but as of right now I have to take out stereo if I want to listen from these SR80i's I just got.
About the power: I am aware. It prompts you after you first boot from installing the sound card, asking if it's been connected.
10 Home x64
Intel Core i5 4670K
Asus Xonar DX
Acer H236HLbmjd
Mionix Naos 7000
76/4 On a good day
SmartScreen
Well that is the end of my limited knowledge, sorry. I hope you have a response from someone more experienced.
Good Luck!:)
bertison
AMD FX-6300.
Onboard.
Iiyama PLE2407HDS.
1920 x 1280
Corsair 750M.
Coolermaster N300.
Logitech K290
Trust Optical Wired
Firefox.
NETWORK:
I just plugged my FP cable back into my motherboard audio and the problem doesn't change. So it's not a problem with the sound card. Could it still be something in the OS or BIOS?
10 Home x64
Intel Core i5 4670K
Asus Xonar DX
Acer H236HLbmjd
Mionix Naos 7000
76/4 On a good day
SmartScreen
Seeing as your case has both AC'97 and HD Audio connections from the from panel,
make sure you are using the HD connection. Pretty sure that the FP header on the Xonar is HD and not AC'97.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
I only have 1 FP audio cable and it's HD.
10 Home x64
Intel Core i5 4670K
Asus Xonar DX
Acer H236HLbmjd
Mionix Naos 7000
76/4 On a good day
SmartScreen
Rules that out then. Seeing as you said that it happens on both the Xonar and onboard, I would tend to believe that it is possible the fpaudio connection is not wired correctly. If that it what it is, I would contact Silverstone and see what they have to say.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
I was thinking that. I sent Silverstone an email yesterday to their EU office, they are yet to reply.
This is a real pain, I'll probably have to send the whole chase back for replacement.
10 Home x64
Intel Core i5 4670K
Asus Xonar DX
Acer H236HLbmjd
Mionix Naos 7000
76/4 On a good day
SmartScreen
I contacted SilverStone, they believe the I/O is definitely defective.
10 Home x64
Intel Core i5 4670K
Asus Xonar DX
Acer H236HLbmjd
Mionix Naos 7000
76/4 On a good day
SmartScreen
