Windows 7: Analog Speaker not detected. USB speaker works
01 Jul 2012   #1
vivekan
Windows 7 ultimate 64 bit
I remember deleting something named "Realtek HD blah blah" from the below screen.
http://www.sevenforums.com/attachmen...1&d=1341120073
From then my normal speaker (audio jack) at the back doesn't work. But my USB speaker works.
I tried to reinstall the audio driver from my motherboard CD and nothing happens.
Please help. This is very annoying.
01 Jul 2012   #2
fireberd
If you deleted RealTek, that is a PC sound (Integrated on the motherboard) and most likely why your speakers are not working. You must have a PC sound device, other than a USB connected device, for the speakers to work.
First step is to reinstall the RealTek drivers. Its best to get the driver either from your PC vendor or Motherboard vendor, as applicable and install that as the first step. Then make sure your "speakers" (sound card) is set as the default playback device in the Control Panel/Hardware and Sound/Sound panel.
Right speaker thinks he's a left speaker
If the volume is low everything works fine, but once you turn it up using the volume button, the left speaker stops working. This only happens when I use the button, and not when I adjust the system sound. I tested it with the audio configuration, and I can hear what's supposed to be the left...
Headphones not detected, internal speaker works
I have a similar problem to previous post, 28-Oct-14, title: "Headphones not being recognized correctly or playing sound". This is on my friend's Toshiba laptop, Windows 7 Home Premium 64bit, and the Dell headphones used to work (they are not currently detected by Windows). The same headphones work...
Only the left speaker works, I have tried many common solutions
I know this problem may have been posted several times but in each post, I never found the solution to my problem. So now here's the rundown. I have Windows 7 Home Premium 64bit with a Realtek HD Audio sound card. Whenever I use several headphones in the front jack, they all work perfectly...
Monitor detected as analog but is digital
My Acer G215H is connected to my nVidia GT 430 via DVI, but in every monitor-related settings screen is says it's analog. The driver for said monitor includes both analog and digital drivers. It's actually very irritating to get 1080P but only at 60Hz. Solution?
Hardware & Devices
Please help - speaker pop
Hello, I have just purchased a brand new HP DV 3174ca laptop and right out of the box it makes a popping noise on start-up, shut down, and awakening from sleep mode. I have installed all the drivers available from HP with no luck, and also tried a factory reset with no luck. Please help,, very...
USB Speaker
Wife has a Gateway n52 laptop with win7 installed. The sound is bad and I want to install a cheap speaker set.She does not listen to music and anything needing great sound but volume and quality as is, happens to be a little to much to bear. Question is can I install a USB speaker system on this?...
