Connecting "HD audio" cable from front panel to sound card
My sound card Xonar D1 doesn't work properly and i wrote to ASUS and they told me to connect the "HD audio" or "speaker" cables from the front panel of motherboard to the sound card's front panel. Is that safe to do? weather it will work or not, is it safe to try?
Most newer cases have two connectors for front panel audio. "HD Audio" and "AC 97". The HD Audio connector is the correct one to use. The AC97 does not have some automatic sense capability that the newer HD Audio does.
The connector is "keyed" (one pin missing) so line it up correctly when installing.
Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080
Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
128GB OCZ Vertex 4 SSD for Win 8
1 TB Seagate drive for backup Internet Speed 40 MB/sec (Cable) Antivirus Microsoft Security Essentials and Malwarebytes Browser I.E9/Firefox Other Info Sonar X2 Professional 64 bit Recording Software with Roland Octa-Capture and MAudio Fast Track Ultra 8R recording interfaces, Frontier Tranzport wireless control unit, Behringer BCF2000 Control Surface.
Five USB connected optical drives for CD Audio production using Nero 11
Other systems: Desktop with i5 3550 CPU, LenovoZ560 Laptop with Win 7 64 bit HP, SP1, new iPad
If you aren't used to messing around inside, do make sure to power down, unplug, and discharge (press the power button after unplugging) the system before messing with any cabling.
System Manufacturer/Model Number Insane hobo technologies. ;-) OS Windows 7 x64 CPU Intel i7 2600k Motherboard Asrock z68 extreme 4 gen 3 Memory G.skill Ripjaw 16gigs @ 1866 Graphics Card Nvidia gtx580 (evga) Sound Card Integrated HD audio + hdmi Monitor(s) Displays 24" ASUS widescreen + 42" insignia Screen Resolution 1080p (1920x1080)
Keyboard Microsoft wireless 3000 (v2) Mouse MS - wireless 5000 (bluetrack) PSU 1 kilowatt SLI/Crossfire rated Silverstone modular Case NZXT Phantom + additional 220 fan Cooling Zalmann Hard Drives 128 Samsung 830
256 Samsung 840
1 western digital 1tb (eSATA)
1 Seagate 1tb (eSATA) Internet Speed depends on if you ask me or my provider. Other Info The above information is provided as is, and the author assumes no responsibility for issues it may cause with your sanity or fanboyism.
Connecting "HD audio" cable from front panel to sound card problems?
