Windows 7: Volume on computer is ridiculously low....Pleas help.
06 Jul 2012   #11
Windows 7 Home Premium 64 bit. SP-1
Northern Ohio
When you right click on the little speaker (lower right of taskbar) select play back divices. How many options do you have? If you have more than one select them one at a time and tick test. The one that works the best right click and set as default.
 Volume on computer is ridiculously low....Pleas help. problems?
Similar help and support threads for: Volume on computer is ridiculously low....Pleas help.
A 32 bit application canot run in windows7 Home basic 64 bit pleas hel General Discussion
Solved BSOD pleas help BSOD Help and Support
Pleas help with BSOD BSOD Help and Support
pleas help: faded and washed out. I am unable to read the text.. Graphic Cards
Backup Error code: 0x81000019 (Pleas help) SSD 60GB Backup and Restore
