Volume on computer is ridiculously low....Pleas help.
pegs204
2:58 PM
I've had my computer for a few months now and for some reason the volume stopped being loud. It's not just a "little off." It's really quiet. I can barely hear the frickin thing.
I've tried everything (all the obvious things a relatively computer-savvy person would try) I can't understand it. Below are some relevant photos. PLEASE HELP!!!!
Picture of the volume controls. Why are those boxes next to the volume sources? Also, the green bar is as loud as it gets. No joke. Unless I use VLC to pump up the sound, this is as loud as it gets from normal playback of media....
Specs of my computer (if this helps)...
Please HELP! It's getting really obnoxious.
Windows 7 64 bit
Windows 7 64 bit
Have you added/removed anything recently? If this is a recent problem, System Restore may fix it.
System Restore can be accessed from Start/Programs/Accessories/System Tools. Select a restore point that is BEFORE you had the problem. System Restore will not delete any user data or e-mails but any updates or new programs will have to be reinstalled (or if they were uninstalled they will have to be uninstalled again). System Restore has an undo function if it doesn't fix it.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
@pegs204
The solution to your problem is likely this one. If that doesn't do the trick let me know and I have another that will definitely fix it.
I have to admit to having the same problem and although resolved, it has now developed into something else. Since using the fix cited above Windows system sounds are back to normal however; my own custom sounds are really quiet. How can Windows drop the volume of some files while retaining it in others? I should add that Windows system sounds are WAV format while my own are MP3's. Maybe that's where the problem lies but if so, how does one tweak Windows to stop that from happening?
Windows 7 Ultimate x64i7 Q8408 GB2 x ATI Radeon H5780
Alienware M17x R2
i7 Q840
M17x
8 GB
ATI HD Audio
2 x 500 GB in RAID 0
you could try converting the mp3's to wav then see if the levels change.
Hewlett packard/p6512uk
FOXCONN 2AA9
2x2gb
ati radeon HD 5450
samsung lcd tv 32"
1360x 768
air!
wireless hp
wireless Hp,optical
1.10mb/s
fireberd, I'm not saying you are wrong but I would like to know how that is possible? As far as I am aware, System Restore takes a snapshot of the drive. When restoring it rolls back to the image you have selected and anything that has been added since that snapshot was taken is lost. It offers no option to select files which should not be restored to a previous date.
I use Rollback Rx which works a bit like System Restore except that you can specify files and/or folders which must be retained. It does that by taking a snapshot at the time of restoring and after restoration it replaces all files and folders you specified from the latest snapshot. Another advantage it has is that you can mount any snapshot as a virtual drive, view it in Windows Explorer, and recover any data you had not specified to be retained.
Alienware M17x R2
i7 Q840
M17x
8 GB
ATI HD Audio
Yes, I had thought of that boohbah but, as they always played perfectly prior to the Windows 7 bug that dropped the volume level, I prefer to locate the source of the problem and eliminate it rather than adapting the system to accept and live with it.
Alienware M17x R2
i7 Q840
M17x
8 GB
ATI HD Audio
System Restore rolls back system files, registry keys, and installed programs.
It's not to be confused with a backup or an image restoration which are more comprehensive.
I use System Restore regularly and have never lost any personal files, although I do keep backups and could restore if it did not work as advertised.
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
System Restore is a great tool. Its saved my butt several times. Its also made me look like "supertech" working on client's PC's.
My suggestion still stands to use it and see if it fixes the problem. As I noted, System Restore has an undo function if it doesn't help.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
@pegs204
Yea. I tried that before. I just tried it again. What's your other solution? BTW, this isn't just on MP3s and such. It's more annoying when watching online media (HBO GO, Netflix, Youtube, etc.).
I'll wait for your response before trying the nuke option and system restoring the thing. Thanks for your help so far.
Anybody got any other suggestions? Anybody know what those boxes mean? I have a feeling they're some weird bug but I'm not sure.
Windows 7 64 bit
Windows 7 64 bit
Also, I just checked out the system restore function. I'm afraid it won't work. As you can see below, the restore points don't go back far enough to when the problem began (seemingly) which was at least a month and a half ago.
Windows 7 64 bit
Windows 7 64 bit
When you right click on the little speaker (lower right of taskbar) select play back divices. How many options do you have? If you have more than one select them one at a time and tick test. The one that works the best right click and set as default.
