Windows 7: What is level in Sound Properties?
07 Jul 2012
K1an
London
Hay,
Thank you for taking the time to read this post.
I was playing around with my computer in the audio tab when i came across Sound properties, then i found something called "Level" I was wondering what is this tab for and what are the setting for:
Thank you,
Kian
07 Jul 2012
Britton30
Windows 7 Ultimate X64 SP1
Mt. Crumpit/Whoville
Can you post a snip of this please?
08 Jul 2012
K1an
London
Quote   Quote: Originally Posted by Britton30 View Post
Here you go,
08 Jul 2012
linnemeyerhere
Windows 7 Ultimate 64
Southern California
These are known as line levels or basically input levels. Think of them as in bound volume.
08 Jul 2012
K1an
London
So what are they actually there for,
08 Jul 2012
Britton30
They control the amount signal for each item. There so you can adjust them to suit different scenarios. Sometimes a signal to a speaker will be too high distorted or a mic will be real sensitive so you lower the level.
Think of levels as water pressure, and volume as a faucet or valve. Higher pressure can give you more fidelity and the volume the decibel level, or loudness.
08 Jul 2012
linnemeyerhere
Southern California
Basically they are there so you don't overdrive the amps ahead of them. A good rule of thumb is the 3/4 rule. When in doubt set it at 70% but if you hear distortions in the recording or through the speakers then back down, if not then raise until you hear distortions or less clarity then back them off. Very doubtful anything in line will heavily distort but I would stick with the 3/4 rule.
 What is level in Sound Properties? problems?
Similar help and support threads for: What is level in Sound Properties?
still here the sound at 0 level from spkrs Sound & Audio
How can i use 1 sound level? Sound & Audio
Windows 7 - Sound at very low level or no sound Sound & Audio
Microphone sound level? Sound & Audio
Low system sound level, high music level? Sound & Audio
