Windows 7: No audio when starting some applications first
08 Jul 2012   #1
wxBen
Running Window 7 x64 ultimate. If I start my computer and I start certain software such as the second life viewer, then there is no audio. And after that, all other applications also produce no audio, even though the volume control shows sounds etc. And the audio is not muted or disabled, and no matter what I do nothing produces any audio.
However, I have learned the following:
A: If I start window media player for example and play some audio I can then start and run everything else and they all have audio fine.
B: If the audio died because I ran SL first, then if I close all sound producing application, and click Computer, Manage, Device Manager, Sound, video and game controller, I see there are two listed:
AMD High Definition Audio Device (this is AMD devices, location 0, Internal High Definitio Audio devices)
High Definition Audio Device (this is a Microsoft driver, location 0, Internal High Definition Audio Bus)
If I disable and enable the second device, then the sound comes back and works.
The issue is I have to use work around A or B, and often forget.
Any ideas for a better solution for this?
08 Jul 2012   #2
fireberd
Usually, AMD audio is HDMI audio, not regular PC audio.
Also, the generic Microsoft HD Audio Codec driver can also be an issue on some PC's. Generally the vendor (either PC or motherboard as applicable) is preferred for the regular PC sound driver.
Your "Speakers" should be the default audio playback device for regular PC audio.
You failed to fill in the My System Spec's so I can't say specifically, reference your PC hardware.
BSOD when starting Autodesk Applications
Hello, I need some help, i can't figure out why this is happening and I was hoping someone were would have some expierience who can help me. Basically the problem I am having is every time i try to start an autodesk program I get a BSOD. I can't seem to figure out why, I've tested by RAM...
BSOD Help and Support
Ventrilo causing loss of audio on all applications, fix on reboot.
Hi, I wasn't sure if this would be the right place to post this or not, I am sorry if it isnt. So I have been having this problem for several months now. While playing video games online with ventrilo, or any other VOIP, randomly it would cause all of my playback audio to stop. I wont hear...
Applications not starting
When I startup certain applications -- the more RAM they use, the more likely it is the problem will appear -- they stall mid-startup, or slow down to the point where they are effectively stalled. The program will show up in the "processes" tab of task manager, with the CPU hovering around 50% and...
General Discussion
Instant Message Applications Pausing Windows Media Player Audio
Okay here's a problem I haven't experienced in any other Windows OS :sarc: The problem simply is that whenever I receive an instant message via Yahoo, AIM, etc., the alert plays but, my Media Player pauses just for that second it takes for that alert to play & continues to play afterward :mad: This...
Music, Pictures & Video
RealTek HD Audio - sounds in applications issue
Hello: I know less about hardware than I do about everything else, so please indulge. And I have found so many threads re: RealTek HD Audio, but they don't seem to apply to me. Mods, please feel free to merge this to another thread as needed. Problem: Sounds/sound effects for SOME (but not...
Audio only works for certain applications
Hi everyone, first time stumbling across a Windows problem I couldn't solve myself. The issue I am having is that audio will only play through specific applications. It will work in WMP and at certain times in video games (in the main game itself but not the intro movies or voice chat, can hear...
