Trouble with audio jack. Plays on speaker but not on headphones! Help?
ElmoRapz
1:43 AM
I am running on a Dell Latitude D630. Just recently my audio jack isnt wanting to understand that my headphones are plugged in. I know that my headphones work cause when I would play them on my iPod they would work perfectly fine. I went into my drivers and uninstalled then reinstalled the audio drivers. I looked for other solutions online and there were none that fit to what I was looking for. the only sound that comes out of the computer are the stock "High Definition Audio Device" speakers.
At this moment I have plugged in 3 sets of headphones and none have been able to get sound out of the audio jack. They are all the simple 3.5mm plugs and I have used them numbers of times when making music on FL Studio or listening to music on Spotify. I know that there has to be a solution because there has never been a problem like this before.
Thank you for any help that you can give me
Windows 7 Home PremiumIntel(R) Core(TM)2 Duo CPU T7300 @ 2.00GHz1 GB
Dell Inc.
1 GB
If you are not using the Dell supplied sound drivers that can be a problem. I used to do a lot of support on the Dell forum and we found that non-Dell drivers either did not work or did not work properly on many Dell's.
Here is the Dell Vista/Windows 7 SigmaTel sound Driver.
Drivers and Downloads | Dell [United States]
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I tried to use this. And i installed it and nothing happened. The headphone jack isnt letting me hear sounds from my laptop. Everything is still going through the speaker, and not through the headphones. I even tried updating all my drivers and nothing is wanting to play. This is what it says on my playback.
Dell Inc.
1 GB
The "High Definition Audio Device" suggests you are not using the Dell SigmaTel sound drivers. Using the Dell drivers is still the first step. There may be other problems but the Dell drivers (properly) installed is the first step.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
