My audio is stuttering.
callmeSly
6:58 AM
Okay. When I am playing videos on youtube the sound stutters. It happens too when I am playing music in iTunes and also in VLC. How would I resolve this?
windows 7 home basic 64-bitAMD A4-3300 APU with Radeon(tm) HD Graphicstotal memory 4 GB usable 3.50 GBAMD Radeon HD 6410D
Emaxx Technology
Emaxx Technology.,Ltd EMX-A55GM-iCafe
AMD Radeon HD 6410D
1024 x 768
Maxtor 7L320S0 ATA Device
generic
Crown
compaq
a4 tech
2mbps
First step, make sure you are using the RealTek sound driver from the motherboard vendor. Many times non-vendor sound drivers either do not work or do not work correctly.
If its not a driver problem, go to the Device Manager, RIGHT click to highlight the RealTek entry and then LEFT click "Uninstall". DO NOT check the box to uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the sound. This fixes a lot of flakey problems.
BTW, I see you have Win 7 64 bit, but only have 4GB of RAM. The big thing with 64 bit OS is that it can address more than 4GB of memory, where the 32 bit OS cannot. Other than memory there is no need for the 64 bit OS.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
this may sound a little bit weird, but i'm not having problems anymore when playing videos using VLC media player. the only problem now is when i'm playing youtube videos. it sounds kinda like static. ANALOGY: uhm like you're putting a dot, pause, after a couple of seconds, dot again then so on. how do i fix this, sir?
Emaxx Technology
AMD Radeon HD 6410D
1024 x 768
generic
Crown
compaq
a4 tech
2mbps
Update or reinstall the Adobe Flash player and see if that help.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
