Volume mixer does not open.
ctell88
10:51 AM
Running windows 7 64-bit. Having trouble with opening my volume mixer. Does not open at all from taskbar or when i try from control panel>sounds. Ive tried looking up this problem on google, but I can never get mine solved. My speakers and headphones still work, but i need to take out the usb from the headphones each time i want to switch where the sound comes out from. Ive tried restarting my comp. Also validated files in sys32 folder from admin cmd. I just dont want to have to run a system restore to open this up.
windows 7 32-bit
windows 7 32-bit
Reinstall the sound drivers, and that may take care of the problem. Use the correct PC Vendor (or motherboard or sound card vendor) drivers as they are the preferred and usually work best drivers.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Im still getting the same results. Re-installed sound drivers from cd motherboard came with. Restared and Nothing still happens when I click open volume mixer on taskbar or when i try to open anything from sound in control panel. next?
windows 7 32-bit
windows 7 32-bit
From your first post, you have to take out your USB headphones before it works. If this is the case, check the Default Playback device in the Sounds panel. If you want the speakers (and mixer), instead of the USB headset to work, without removing the USB headset, you may have to manually change the default playback device back to your "Speakers" (sound device).
I've seen USB headsets cause many different problems.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
