[Solved] Flash audio quiet in one side.
Starting last night the audio on flash player is very quiet on the left side as if it's out of balance. The problem is only with flash because everything else sounds fine, only flash content is having this problem.
I've searched through any settings I can find but there is no where to edit the audio settings of flash. Does anyone have suggestions of how to fix this?
(Additional info, my last headset was broken and sound coming out of the left side was quieter so I had to set the volume balance to correct it, but last week I got a replacement headset working fine up until tonight. Now this is the same issue BUT only with flash, the sound works fine with everything else, so it's not the headset, it's a software problem.)
Browser: Chrome
Headset: Logitech G35
Again I'm certain it's a software issue, specifically flash..
