Windows 7: Creative sound card not detected
14 Jul 2012   #1
Ndman55
Windows 7 Ultimate 64 bit
I have just acquired a creative Audigy 2 Platinum Pro (Model SB0290) from a friend, however Windows can't detect it so I can't install the driver. In device manager a device called Multimedia Audio Controller shows up under Other Devices.
Thanks in advance!
14 Jul 2012   #2
fireberd
If you haven't done it, disable the Integrated (on the motherboard) audio in the BIOS first. Two audio devices can conflict and cause problems.
The Multimedia Audio Controller is part of the sound device/drivers. When you get the SoundBlaster properly installed that should go away.
On the other hand, the old (and that is an old sound card) card may not work on your Win 7 system or may be defective. Actually, if you have a relatively new PC (or motherboard) the integrated sound on the motherboard is as good or may even be better than the old Audigy 2 sound card.
14 Jul 2012   #3
Ndman55
I disabled that yet it still didn't work. Windows still doesn't think it's attached
14 Jul 2012   #4
fireberd
I would suspect that either its bad or not compatible. That is a relatively old sound card. I had one of those back in the Windows XP days.
Did you try reseating the card (with the PC powered off)?
14 Jul 2012   #5
bobkn
Windows 7 Pro X64 SP1
I'm not sure what to expect from Windows.
Did you try installing the Creative drivers directly?
http://support.creative.com/Products...rodName=Audigy 2 Platinum&subCatName=Audigy&CatName=Sound+Blaster&VARSET=prodfaq:PRODFAQ_150,VARSET=CategoryID:1
(The card is supposed to be supported under Win7 X64.)
07 Aug 2012   #6
SirTenTea
Windows 7 Home Premium 64Bit
I recently installed a new power supply and a new Video card. The Video card is installed, as was the previous one, in the PCI Express 2 X16 slot. When I restarted my PC the Xi-Fi Extreme sound card was seen again. I reinstalled all the drivers for it etc and it worked for one whole day. Then the sound card disappeared again. In fact it disappeared in the middle of playing a video. This card is a fairly old one but why was it seen again after the other hardware upgrades and then lost again? I am running Windows 7 64bit.
07 Aug 2012   #7
essenbe
Windows 7 Enterprise X64/Windows 10 Enterprise X64/Windows 10 Pro X64/Linux Mint
Check the proper seating of the card. I had a similar problem with a sound card. After hours of figuring it out, I found the problem was alignment with the case. When I screwed the card in, it picked up the rear of the card just enough where Windows would see it sometimes but most of the time didn't. I loosened the bracket screws just a slight bit and never had another problem. YMMV and you may have a different problem.
19 Nov 2013   #8
rfxcasey
Sorry to resurrect this thread, however, for the record it need be said. While these cards are getting very long in the tooth, it is still possible to get great value out of them as they are cheap as dirt on ebay. Creative no longer updates drivers for most if not all the Audigy 2, 1 and Live series of sound cards and none of which are officially supported in Windows 7 to my knowledge. There are however a couple of aftermarket drivers available such as the KXproject drivers that work remarkably well in 7.
That said, the nature of modern machines working with older hardware can be a bit more complex then just plug and play. If your on a modern motherboard, as am I, search in your BIOS under the PCI settings and look for a setting the likes of 'PCI BIOS priority' or something similar. If there is an option to prefer 'LEGACY BIOS' select it, save the setting and restart the machine.
My new PC refused to acknowledge my Live or Audigy cards until I changed this setting. Every BIOS will probably call it something a bit different but close enough for you to identify. Haven't tested this with any other 'Legacy' PCI devices but this will probably be the case for most others similarly.
Hope this helps someone.
20 Nov 2013   #9
Indianatone
Quote   Quote: Originally Posted by rfxcasey View Post
Agreed, my Sabertooth declined to allow my awesome Audigity 2 ZS to work in the only PCI slot on the motherboard. Worked fine and dandy on a 2 year old Asus AM3 motherboard on 64 bit Windows 7. I was using legacy bios. Had to buy a new card (shame ). You sometimes have to retire perfectly good hardware as things move forward. Have placed the ZS sound card in an older motherboard and it is sounding great. They were designed for Windows XP.
21 Nov 2013   #10
rfxcasey
Its rather disturbing that Creative Labs forces you to update from your otherwise perfectly good card by simply dropping driver support. In contrast you can get just about any legacy video card to work with at least basic functionality on modern systems. However this is usually due to Windows installing some generic driver for it. Doesn't seem to work like that with Creative sound cards. I'm sure third party drivers really get creatives goat and if so I'm glad.
Paid over 200 dollars for my Live! Platinum back in around 2000. I think the last driver update from Creative was in 2004. They actually dropped support even before certain issues were resolved running under XP. I remember in particular several titles from Ubisoft including Splinter Cell had horrible static. The only fix was to start using the KXproject drivers and I have never looked back since. Still using an Audigy under Window 7 today I have a bit of satisfaction knowing that when Creative tried to screw me, I turned around and screwed them in some small part.
Used to lover Creative cards however having experience Creative's policy of forced obsolescence I don't think I will ever buy anything from them ever again, if not just out of principle. The problem is, for most people if the sound card is working they don't see a need to upgrade to 24bit resolution or 192Kbps sampling rates. Creative worked themselves into a corner by making sound cards so good that from one generation to the next the improvements are so minimal for your average user upgrading is not justified.
I don't mind spending hard earned money if there is a good reason for it, however Creative's need to boost revenue alone is not a good enough reason if you ask me.
Basically all you wind up doing to paying for a new driver and as a side effect replace perfectly good hardware for little to no reason. The beautiful part is, now you can get some really great 'Legacy' sound cards on Ebay for under $20 buck that work great in Win 7 if you know what you are doing.
Low volume with new sound card(Creative Sound Blast 5.1 VX)
Hello! I got a new sound card today. Installed it, installed the drivers from the CD, plugged in the headphones and it works. But the sound levels are way to low. I raised the volume in all the places I could find, but it's still a bit low. Here's the card: Creative Sound Blaster 5.1 VX...
Creative Sound card problems
ok here goes I have read about 62 pages of threads looking for answers and tried the pinned post here about Creative sound cards THIS is going to be a long one ;) I had this computer built for me and have basically had problems updating the drivers,program from day 1 Only change I made to this...
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Creative Sound card
I've got a Creative Sound Blaster X-Fi Xtreme Audio. I have 2/2.1 speakers. What jack in the back of the card should I be in? When I run creative diagnostics I hear the left and right speaker but not my center speaker. With the 2/2.1 speakers do you stay in the green jack?
Upgraded to W7. No sound. Creative Xfi card. Help!
I upgraded from Windows XP to Windows 7 Home Premium 32 bit. My sound card is a Creative X-Fi Audio Processor (WMD). I am not sure if that is the actual model name. That is the name that the device manager gives me. RE-installing drivers from Creative doesn't help. Tried the Daniel_K drivers and...
Problems with my Creative Sound Card.
Hi all, I've been having problems with my sound card drivers ever since I upgraded to Windows 7 64 from Windows Vista 32. I must admit I messed up by not writing down what specific sound card is in this laptop (Dell Inspiron 1520) and I have not been able to find any drivers from Dell.com. I...
Drivers
