No audio Device is installed red X on speaker
  1. Posts : 16
    32bit windows 7
    it was alrdy set to that thats all the speakers i got
  2. Posts : 53,364
    Windows 10 Home x64
       #12
    I edited my post as I saw it is a laptop and speakers were already default. A Guy
  3. Posts : 16
    32bit windows 7
    hey thats the problem i was wounder cause when i click configure nothing happens like nothing pops up neither with test its like the button dont even work
  4. Posts : 53,364
    Windows 10 Home x64
       #14
    Click on the speakers, and click the Properties button. Post snips of the general and levels tabs
    Did this problem just start? Did you change anything before it started? If it just started, you might try a system restore point from just before it began.
    A Guy
  5. Posts : 16
    32bit windows 7
       #15
    Wow there nothing even in there.....
    Attached Thumbnails Attached Thumbnails No audio Device is installed red X on speaker-ret.png
  6. Posts : 16
    32bit windows 7
       #16
    this the general
    Attached Thumbnails Attached Thumbnails No audio Device is installed red X on speaker-jk.png
  7. Posts : 53,364
    Windows 10 Home x64
       #17
    Is this a new PC? Did the audio ever work? Is this the only issue? I must do some work for a while, but I will ask for more help and be back later. A Guy
  8. Posts : 16
    32bit windows 7
       #18
    ight heres the problem i delete files which i dont even know n next day it just stopped working i thought it was just the audio device so i just download a new one i think i deleted a file that i needed
  9. Posts : 53,364
    Windows 10 Home x64
       #19
    Try a system restore point from before it began.
    System Restore
    Try SFC if no help
    A Guy
  10. Posts : 16
    32bit windows 7
       #20
    yea this happened a while back the system restoere point wont help and the sfc doesnt work for me idk y it just stops at 15%
