Problem with driver to IDT high definition audio CODEC
  1. Posts : 4
    windows 7 Home premium 64 bit
    Any suggestions would be appreciated. My audio no longer works. This message appears when troubleshooting:
    There is a problem with the driver to IDT high definition audio CODEC. Reinstalling the driver might fix the problem.
    The automatic "apply this fix" does not work.
    What should I do?
    Thanks.
  2. Posts : 2,913
    Fill in your system specs. Without it, we have no idea what hardware you own.
  3. Posts : 4
    Thanks for your patience. I added what I could find to my system specs. Is that the correct information to be helpful?
  4. Posts : 2,913
    Yes, that's helpful. Have you visited HP and looked for the correct audio driver for your laptop?
  5. Posts : 4
    Sorry, but I don't know what you mean my this question. I have searched HP but do not know what to look for. An audio driver does not seem to be listed with the specs.
